salf100
Visits: 82
Dan in Seattle, do you have the contact info for that guys shop? I found a syncro shifter on ebay for $150-$250 range still in the boxes. Not to bad. How bout Fenton shifters. Anyone use these?
1964 F100 292YBlock
46yblock
Visits: 7.8K
 These are pics of a Jeep top shifter in a Ford 3 speed toploader. A little over three years ago a man had the conversions listed for sale on ebay. I talked with him a fair amount and tried to find the correct donor jeep trans locally, but didnt follow it through. The jeep trans was from the mid to late 70's as I recall.
Visits: 497.8K
Street Rodder also did write up on the Jeep conversion. Quite a few years ago. Try Sept 04. I think that it is the correct issue, but the description I have has a title something like "Putting the shift Lever in the right spot on a Ford Toploader" For anyone tring to locate an magazine article, go to http://hotrodindex.150m.com/
Dan in Seattle
Last Active: 14 Years Ago
Visits: 77
Sal, what I tripped over is the same as Mike pictured. This guys shop is not commercial, just a collector and doubt he ever ever lets go of anything. Be careful of the bell housing/input shaft lengths with these twuck bell housings.
Dan in Seattle
salf100
Visits: 82
Ok, looks like we are getting closer to the mystery......  I read on line last night that the correct Jeep trans. to use is the T-150 from 1976 era. Thanks for all the info fellas. Once we figure it all out, I think I will do a tech article on it. So keep the info flowing!
1964 F100 292YBlock
aussiebill
Posts: 1.8K,
Visits: 11.4K
Make sure you dont buy the 4 speed top, they are similar except for the reverse fork. I just did my 4 speed t/loader, and once you remove the forks, rails, detent balls and find plugs to seal the case, then you,re there!
salf100
Visits: 82
Well, I emailed Street Rodder and they blew me off. Told me they could not help me with anything that old, as far as the magazine. Im still looking! Low and behold, they got back to me! Dec 2000 issue I guess and it was done by David Kee toploaders. Soon as I get more info I will post it.
1964 F100 292YBlock
64crew4x4
Visits: 7
Any word on this Mod...? I have a 64 F100 Custom cab With 292 and 3 speed....Floor shifter would be a cool upgrade....
Visits: 497.8K
Street Rodder had a article about using the jeep top cover on a top loader. It could be either of the two articles below, probably the latter nbut not sure
Feb 74 Top Shift for late Ford
Sept 04 Putting the shifter where it belongs on a top loader.
