WTB - Oil Troughs for timing chain lubrication.
Posted By Ted 15 Years Ago
Posted 15 Years Ago
I’m looking for some oil troughs that were on the early blocks used for directing additional oil to the timing chain.  These are just a stamped steel piece that fastened to the block behind the timing chain with a single screw.  I can also use the fuel pump lobe counterweights that were also discontinued in 1956 so I’m interested in those also.  Here’s a couple of pics.
If you have any of these you’d like to get rid of, then contact me using the email address or the phone number at this site address.  http://www.eatonbalancing.com/contact.php
Thanks, Ted.
carl
Posted 15 Years Ago
Posts: 1.2K, Visits: 20.6K
Ted  I have seven yblocks that i am going to part out in the next few weeks,not sure what year they are but if the have what you need i will let you know  Carl Lynn
Oldmics
Posted 15 Years Ago
Posts: 710, Visits: 78.1K
Do you believe that the fuel pump counter weights are benificial in camshaft balancing?
Oldmics
Posted 15 Years Ago
Last Active: 7 hours ago
Posts: 3.7K, Visits: 323.2K
Ted:
I'm intrigued.  Are you finding the timing chains need a little more oil?  Or maybe trying to control windage at the front?
Oldmics
Posted 15 Years Ago
Inquiring minds want to know! w00t
Oldmics
Posted 15 Years Ago
Oldmics (12/2/2010)
Ted. Do you believe that the fuel pump counter weights are beneficial in camshaft balancing?
A definite Yes when the counterweight is used in conjuction with the fuel pump lobe.  How much benefit this has on the overall life of the engine is debatable though.  The original engineering for the Y saw fit to include the fuel pump counterweights, timing chain oil troughs, and rocker arm baffles on the pre ’56 engines but I’ll speculate that the removal of these items in 1956 were the result of the push to increase assembly line production as well as cost cutting measures.
Ford did bring the fuel pump counterweight back into production on the 271HP 289’s though so the engineers did recognize some benefit from the use of it in a performance application.
Posted 15 Years Ago
Hoosier Hurricane (12/2/2010)
Ted:  I'm intrigued.  Are you finding the timing chains need a little more oil?  Or maybe trying to control windage at the front?
I’ll say Yes on the need for more oil.  Those engines without the oil troughs do appear to be more heavily worn on the timing gears where the links on the chain are digging in.  This is just a random observation as I don’t have a clue as to the mileage on the core engines I’m tearing down but the chains on non-oil troughed engines do appear to have more slack in them than the chains on engines with the oil troughs.  The additional slack looks to be primarily due to the wear in the gears more than stretch in the chains.  So with that in mind, I just feel more comfortable with the oil troughs in place when I can put them on as these troughs help to better direct any oil that's present directly onto the lower timing gear which is then carried back up the chain.
Posted 15 Years Ago
Ted:
Early inline chev sixes had a short tube extending over the timing gears, connected to the camshaft bearing oil passage.  Could this idea help a Y?  I think Speedpro's engines have a small (.030?) hole drilled into the front oil passage to squirt lube onto the crank gear.  Richard Gaston used to scratch a small notch in the front cam bearing to bleed extra oil to the cam thrust area.  I have seen several engines with wear in that area.
stuey
Posted 15 Years Ago
Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)
Posts: 443, Visits: 3.8K
i see you've had no offers, i've been looking ever since reading your article on camshaft balancing and have not come up with anything. i think i could bash up a trough with a big hammer and a piece of rusty tin but the counter wt. would need some help. i'm guessing you are going to be more successful than me in obtaining one, any chance of posting a flat on pic.
i'm guessing its the same thickness as the spacer an could scale the pic from the bore to come close?
thanks in advance
stuey
Rudder2fly
Posted 15 Years Ago
Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)
Posts: 160, Visits: 35.5K
Ted, Thanks for the postage. Merry Christmas to you. Gene Stoehr Eddyville, Ky.
56 VIC  Gene Stoehr Sr.
