WTB - Oil Troughs for timing chain lubrication.
http://forums.y-blocksforever.com/Topic52365.aspx
By Ted - 15 Years Ago
I’m looking for some oil troughs that were on the early blocks used for directing additional oil to the timing chain.  These are just a stamped steel piece that fastened to the block behind the timing chain with a single screw.  I can also use the fuel pump lobe counterweights that were also discontinued in 1956 so I’m interested in those also.  Here’s a couple of pics.
If you have any of these you’d like to get rid of, then contact me using the email address or the phone number at this site address.  http://www.eatonbalancing.com/contact.php
Thanks, Ted.
By carl - 15 Years Ago
Ted  I have seven yblocks that i am going to part out in the next few weeks,not sure what year they are but if the have what you need i will let you know  Carl Lynn
By Oldmics - 15 Years Ago
Do you believe that the fuel pump counter weights are benificial in camshaft balancing?
Oldmics
Ted:
I'm intrigued.  Are you finding the timing chains need a little more oil?  Or maybe trying to control windage at the front?
Inquiring minds want to know! w00t
Oldmics
Oldmics (12/2/2010)
Ted. Do you believe that the fuel pump counter weights are beneficial in camshaft balancing?
A definite Yes when the counterweight is used in conjuction with the fuel pump lobe.  How much benefit this has on the overall life of the engine is debatable though.  The original engineering for the Y saw fit to include the fuel pump counterweights, timing chain oil troughs, and rocker arm baffles on the pre ’56 engines but I’ll speculate that the removal of these items in 1956 were the result of the push to increase assembly line production as well as cost cutting measures.
Ford did bring the fuel pump counterweight back into production on the 271HP 289’s though so the engineers did recognize some benefit from the use of it in a performance application.
Hoosier Hurricane (12/2/2010)
Ted:  I'm intrigued.  Are you finding the timing chains need a little more oil?  Or maybe trying to control windage at the front?
I’ll say Yes on the need for more oil.  Those engines without the oil troughs do appear to be more heavily worn on the timing gears where the links on the chain are digging in.  This is just a random observation as I don’t have a clue as to the mileage on the core engines I’m tearing down but the chains on non-oil troughed engines do appear to have more slack in them than the chains on engines with the oil troughs.  The additional slack looks to be primarily due to the wear in the gears more than stretch in the chains.  So with that in mind, I just feel more comfortable with the oil troughs in place when I can put them on as these troughs help to better direct any oil that's present directly onto the lower timing gear which is then carried back up the chain.
Ted:
Early inline chev sixes had a short tube extending over the timing gears, connected to the camshaft bearing oil passage.  Could this idea help a Y?  I think Speedpro's engines have a small (.030?) hole drilled into the front oil passage to squirt lube onto the crank gear.  Richard Gaston used to scratch a small notch in the front cam bearing to bleed extra oil to the cam thrust area.  I have seen several engines with wear in that area.
By stuey - 15 Years Ago
i see you've had no offers, i've been looking ever since reading your article on camshaft balancing and have not come up with anything. i think i could bash up a trough with a big hammer and a piece of rusty tin but the counter wt. would need some help. i'm guessing you are going to be more successful than me in obtaining one, any chance of posting a flat on pic.
i'm guessing its the same thickness as the spacer an could scale the pic from the bore to come close?
thanks in advance
stuey
By Rudder2fly - 15 Years Ago
Ted, Thanks for the postage. Merry Christmas to you. Gene Stoehr Eddyville, Ky.
stuey (12/9/2010)
........any chance of posting a flat on pic.
I'm guessing its the same thickness as the spacer an could scale the pic from the bore to come close?
Stuey, here’s a pic of a couple of the oil troughs next to a ruler.
thanks very much Ted   really appreciate it
has bit more curve than i thought but thats ok. any chance of a similar pic of the counter balance?
some time after xmas no hurry. i'm away for xmas with family this year
MerrY  Xmas and a happY New Year to all Y-blockers
stuey
stuey (12/23/2010)
.....any chance of a similar pic of the counter balance?
MerrY  Xmas and a happY New Year to all Y-blockers,   stuey
Here’s a pic of the fuel pump lobe counterweights against some machinist rules.  The counterweights are about 0.160” thick.
here's wishing everybody a happy and prosperous new year
i'm just back from the kids carrying an extra 7lbs weight    thats not good it takes months to shift..
Ted thanks a bundle for the counter wt. pics they scaled up good.   can't come up with any thing 160 thou with out surface grinding but 4 mm is only 2 thou shy and its off the shelf   gonna use grade 01 tool steel its a bit better than mild steel and i'm thinking it will be better for the keyway     now there's another problem. i think the key way is 5/32 and the bore is 1".  the only broaches i've seen are 5/32 B and the only sleeves of 1" do not go down to 5/32
any comments  advice??
thanks folks
stuey
Stuey:
The originals had to have been stamped.  Hand building them like you are proposing would have been too slow and expensive.  Even Ford must have thought stamped ones were too expensive and eliminated them.  Thousands of new car buyers never new the difference.  The use of tool steel would be overkill, they are clamped in place, there would be no load on the key. Are you thinking of producing them for sale?  It would be a very small market.  JMHO
By yalincoln - 15 Years Ago
just a stupid question, did they change the weight of the fuel pump cam?
By marvh - 15 Years Ago
yalincoln (12/31/2010)
The fuel pump cam was changed in 56 when the dual diaphragm pumps became the norm and wear appeared on the outer surface.
The new cams were heat hardened. You can usually see a blued tinge to the cam when comparing to a 55 cam.
As to weight of cam I have never weighed one. Visually they look the same thickness
By stuey - 14 Years Ago
John  thanks for the comments
i have no intention of going into production  i'm a backyard DIYer who loves to have a go.
since getting the Y powered F100 i've mastered TIG welding (only in the down hand position)  replaced the drivers side floor    i've also learnt how to bend a new oil pickup tube using sand fill method      the first attempts tore apart but with a little patience it worked    all my existing pickups are well bashed    now i'm learning about broaches and keyways all thanks to the Y-block
a lot of info is on You-Tube from a gent called Tublecain all basic but good. home casting is on the horizon and home made headers
the truck came from Klamath falls Oregon and i've seen a couple of contributors on this site that may be from that area   the previous owner was Don Tidwell who also had a Y powered Morris Minor !!!
happy new year   stuey
By Ted - 14 Years Ago
stuey (12/31/2010)
.........now there's another problem. i think the key way is 5/32 and the bore is 1".  the only broaches i've seen are 5/32 B and the only sleeves of 1" do not go down to 5/32
On the smaller diameter holes, I typically have to build my own broach collars depending upon the key cutter being used.  Here’s a picture of a 5/8” diameter ‘B’ collar that inserts into a 1" diameter offset bored bushing for doing the 5/32” key slots in Y-Block camshaft timing gears.  And here’s also a picture of a ‘C’ collar machined for a ‘B’ cutter.
thanks for taking the time and effort to reply.
i'll go for the offset bush, i did find a Dumont 5/32 C broach at Fastenal for    wait for it       $236.88!! too rich for me.
now its time to knuckle down and do it
thanks a lot
stuey
By Don Woodruff - 14 Years Ago
May be a bit crude for you but an 1/8 in mill and a file may substitute for a broach especially in a non critical fit as this appears. Ted: Neat solution for adding keyways.
I am also thinking Ted as you have an original counter weight, some material, bluing, a band saw, and a belt sander, along with a couple of drills and a Mill might suffice to rough out a suitable copy. Lots of time involved, and you would really need to want one.
The trough would be a major task if the original was to be duplicated but a simplified version could be roughed out.
Don Woodruff (1/5/2011)
I agree. No broach is needed. A die grinder, Dremel, jig saw, band saw, hack saw, etc can be used to start the notch. Finish it with a file.
thanks for the tips
i'm not above finding alternative methods    i'm hoping to borrow the broach from a model engineer friend. if not i've considered drilling a 5/32 hole on the circumference of the 1" hole prior to drilling & reaming said hole this would give me a notch that would require minimal filing for the keyway
i've got a 25mm drill bit that should leave enough meat for a 1" spiral flute(needed to stop shudder on the pre drilled notch) reamer to work on
another problem with the broach is that the counter balance will need to be backed with a piece of scrap to prevent it dropping between the teeth   i wondered why they are advertised with a min cut
thanks again everyone
stuey
all i need to do now is try to do a static balance with an old eccentric!!
next the oil trough but thats on hold   the wifes pulled a muscle in her leg and is in great pain so i'm the "go fer"
thanks Ted and everybody else      this is a great site for beginners like me
stuey
