WTB - Oil Troughs for timing chain lubrication.
Posted By Ted 15 Years Ago
Don Woodruff
Posted 14 Years Ago
Posts: 190, Visits: 1.6K
May be a bit crude for you but an 1/8 in mill and a file may substitute for a broach especially in a non critical fit as this appears. Ted: Neat solution for adding keyways.
Don Woodruff
Posted 14 Years Ago
I am also thinking Ted as you have an original counter weight, some material, bluing, a band saw, and a belt sander, along with a couple of drills and a Mill might suffice to rough out a suitable copy. Lots of time involved, and you would really need to want one.
The trough would be a major task if the original was to be duplicated but a simplified version could be roughed out.
Posted 14 Years Ago
Don Woodruff (1/5/2011)
I agree. No broach is needed. A die grinder, Dremel, jig saw, band saw, hack saw, etc can be used to start the notch. Finish it with a file.
stuey
Posted 14 Years Ago
Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)
Posts: 443, Visits: 3.8K
thanks for the tips
i'm not above finding alternative methods    i'm hoping to borrow the broach from a model engineer friend. if not i've considered drilling a 5/32 hole on the circumference of the 1" hole prior to drilling & reaming said hole this would give me a notch that would require minimal filing for the keyway
i've got a 25mm drill bit that should leave enough meat for a 1" spiral flute(needed to stop shudder on the pre drilled notch) reamer to work on
another problem with the broach is that the counter balance will need to be backed with a piece of scrap to prevent it dropping between the teeth   i wondered why they are advertised with a min cut
thanks again everyone
stuey
stuey
Posted 14 Years Ago
all i need to do now is try to do a static balance with an old eccentric!!
next the oil trough but thats on hold   the wifes pulled a muscle in her leg and is in great pain so i'm the "go fer"
thanks Ted and everybody else      this is a great site for beginners like me
stuey
