Porting Exhausts
Posted By grovedawg 16 Years Ago
grovedawg
Posted 16 Years Ago
Last Active: 14 Years Ago
Posts: 246, Visits: 622
Doc Frohmader wrote an article about porting Y-Block heads, and it's online at Egge's website HERE
Towards the end of the article he talks about port matching the intake side to the intake gasket- not much work was needed there. But he also references the exhaust side, and talks about that corner that is blocked off. It's visible in this picture HERE
Doc says not to take that corner out as it's a low flow area, and removing it will drop exhaust velocity. But, I recently watched a YouTube video where Tim removes that corner to match the entire port to the exhaust gasket. That video is HERE
At 3:06 mins into the video you can see that he has nicely matched the ports to the gasket, and has removed a large bit of metal that makes up that corner.
Any ideas as to what I should do? Right now, I've only matched the port to the gaskets on the outside edges of the port, and have completely left that blocked off corner alone.
Heber City, UT (15 mins outside of Park City- basically it's in the mountains)
55 Effie
Talkwrench
Posted 16 Years Ago
Posts: 898, Visits: 23.2K
Im no expert but I would say better to leave it as taking too much out will lower velocity. taking more out might be ok for forced induction applications... rememeber you can't go back once its gone, just tidy up around the edges. Wink
Y block Billy
Posted 16 Years Ago
Posts: 1.6K, Visits: 5.2K
Good stuff in Docs article, I think Johns expertise speaks for itself and it shows in his new heads.
55 Vicky & customline
grovedawg
Posted 16 Years Ago
I keep wondering about the loss of velocity if I did remove them. I just need to trust what people have found out through flow benches. Thanks duders
55 Effie
mctim64
Posted 16 Years Ago
Last Active: 4 Months Ago
Posts: 2.4K, Visits: 5.0K
Yes I  have removed the corner area to match the gasket, but I leave the hump in and just clean up the pocket.  I don't have a flow bench but I do have a great low end in my '58, the "Brick" and "Elwood" are mostly top end but pull pretty good on the low. I also try to make the header/manifold slightly bigger than the exhaust port, 'sposed to discourage back flow.  I'm sure Ted and John will chime in soon.
grovedawg
Posted 16 Years Ago
Thanks Tim! So you just relieve from the manifold surface back to the hump. In essence it's like a radius from the peak of the hump in the center of the port that meets the edge of the exhaust manifold. Thanks again!
55 Effie
grovedawg
Posted 16 Years Ago
This is also a side question for you Tim (or anyone for that matter). But I've heard conflicting reports on exhaust size and velocity theories. What exhaust primary would you recommend for a 1.6 valve exhaust?
I was planning on a 1 5/8 exhaust primary, but an engine builder that I respect said stay with the 1 1/2 to maintain velocity. What do y'all recommend? Obviously I'll follow your advice Tim, and enlarge the manifold flange to cancel reverb into the ports etc. But, give me some advice cause I'm still a newb! Smile
55 Effie
Posted 16 Years Ago
I think you'd want at least 1 5/8 primaries. Hold out for a little while longer and we'll know lot more about it. A very comprehensive exhaust dyno test will be taking place some time soon.
mctim64
Posted 16 Years Ago
I am running 1 5/8" primaries on the FED but only 1 1/2" on the '58 Effie and the "Brick", I have a kit for a set of tuned headers with 1 5/8" but just haven't assembled them yet.  As Charlie Mc said there should be some good info on headers coming up soon.  I am always learning too. Wink
grovedawg
Posted 16 Years Ago
Thanks Charlie and Tim! The nice thing is I'm still probably about 3 weeks out form building my exhaust headers. So, hopefully the dyno testing will be done by then! Smile
55 Effie
