Porting Exhausts
Posted By grovedawg 16 Years Ago
mctim64
Posted 16 Years Ago
Last Active: 4 Months Ago
Posts: 2.4K, Visits: 5.0K
LOL!  Nice Doug! Tongue
grovedawg
Posted 16 Years Ago
Last Active: 14 Years Ago
Posts: 246, Visits: 622
Is Doug a Cyclops??? I wonder if we can measure the difference in efficiency/performance of cycloptic head porting, verses the more traditional two-eyed approach! Smile
If one eye works better I'll need to fashion an eye-patch of sorts to block out vision in one eye. I'm sure there's a pirate forum somewhere that I can ask about building an eye-patch in my garage... I just need to make sure it's a "TRADITIONAL PIRATES ONLY FORUM." I can't have any of this non-traditional crap.... w00t
Heber City, UT (15 mins outside of Park City- basically it's in the mountains)
55 Effie
grovedawg
Posted 16 Years Ago
Those heads are currently sitting on the dyno engine awaiting a break in shop activities so the engine can be put back on the dyno. Probabaly in a couple of weeks the way things look right now.Two sets of ported heads will be tested back to back on the same day when it does happen.The second set of ported heads (more conventional porting) will be used for the exhaust and header tests.
Thanks Ted. I can patiently wait for the results. I do appreciate all of the knowledge you share!
55 Effie
grovedawg
Posted 16 Years Ago
One more quickie post on the same thread...
Doug T (7/2/2010)
Flow testing on a bench will show that a flat roof will flow more but in all instances there needs to be a square to round transition for the header tube some place between the flange of such a port and the tube that will speed up the flow causing an increase pressure. I like very smooooth flow paths with a flow reversion as the only change in cross section until well beyond the exhaust flange. Therefore I make the transition as part of the port itself.
So, you're saying two things that are news to me. The first: That a flat roof flows better. Of a D port, with the flat side of the D on the top of the port, or bottom of the port?
Second: That you like to radius the port side into a circular shape to match the circular shape of the exhaust tubing coming out of the flange? (Did I catch that right?)
My intuition about the second point is that might lead to more reversion without having some disparity between the square exhaust ports and the circular exhaust tubing. But, I'm still a total newb! Blush
55 Effie
mctim64
Posted 16 Years Ago
"D" port has the flat on the bottom and curved on top, the gasses natually flow to the top.
grovedawg
Posted 16 Years Ago
So, I finished all of the porting. I'm going to finish cc-ing the chambers and modifying them until they are all the exact same. At that time I'll go through the ports one last time to clean out any final burs, and rough out the intakes one last time. But otherwise I appreciate all your guys help. Here are some pics. Smile
55 Effie
YellowWing
Posted 16 Years Ago
Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)Supercharged (296 reputation)
Posts: 296, Visits: 1.8K
Good job. It will be interesting to hear how they perform when you get it back together. Mike
1956 Fairlane Victoria (ORREO)
Overlooking Beautiful Rimrock AZ
grovedawg
Posted 16 Years Ago
Yellow Wing: Thanks. I've had them on a flow bench and they tested to 159-160CFM per port. So, I'm really excited as well. Not to bad for my first crack at porting eh?
I can't wait to put a header and an exhaust and see how they RUMBLE! Cool
55 Effie
