Deposits are now being taken for the next run of aluminum heads.
Posted By Ted 16 Years Ago
Posted 16 Years Ago
Posts: 3.7K, Visits: 323.8K
Pegleg:
I can tell the difference.  Look inside.  Your name is in there.
How things change.  When I first built my F Bird clone in '79, I only had one bonnet, and it was on my race car.  So I took a similar size chrome aftermarket air filter, hammered the louvers shut and brazed them, added the bump on the back for the vent flap, and the bump on the side for the pressure hose fitting, brazed in an inlet hose nipple, brazed the base onto the top, added a little bondo and some aluminum paint, and put it on the Bird with the repro hose from Don Antilla.  Nobody ever questioned it.  The local club members had never seen an F Bird, they had no clue.  Of course now, thanks to your efforts, I have a correct appearing one on it now.
DANIEL TINDER
Posted 16 Years Ago
Posts: 1.8K, Visits: 154.6K
[b]pegleg (5/28/2010) If John's heads don't look absolutely original, 99% of the club members won't buy them. Unlike the guys here, they're not going to modify anything that will affect their cars value.,
Frank,
I'd be surprised if half of the "driver" EarlyBirds out there still had original heads. Combination of poor quality oil, inattentive maintenance, and plentiful availability of inexpensive Y-Block replacement/service heads over they years (that dealers were only too happy to clear off their shelves) means many originals got junked. Aside from from core plug issues re: earlier years, as long as aluminum branding logo isn't obvious, once the new heads are proven & readily available, the same incentive may very prevail. Why trust a machinist to rebuild iron heads and install hard seats, when you can just bolt-on lighter replacements that will improve performance & tolerate higher CRs to boot?
6 VOLTS/POS. GRD. NW INDIANA
Larry D
Posted 16 Years Ago
Supercharged (228 reputation)Supercharged (228 reputation)Supercharged (228 reputation)Supercharged (228 reputation)Supercharged (228 reputation)Supercharged (228 reputation)Supercharged (228 reputation)Supercharged (228 reputation)Supercharged (228 reputation)
Posts: 150, Visits: 1.4K
I hate to say it, but I've driven a few of those dead stock EarlyBirds and a couple of them were so badly tuned and maintaned a 6-cylinder would have left them in the dust.
Teapots and dual diaphram distributors may bring in the trophies at T-Bird meets but enjoying what you drive has always been my way of thinking.  Well tuned and running what the factory forgot with a little new technology usually equals better fuel economy and performance.
I don't own anything that's stock and I never will, so my deposit is down for a set of heads that I've been waiting 15 years to hold in my hands.
All I can say is... Thank You John!
Larry D
Winnipeg, MB Canada Eh!
http://www.y-blocksforever.com/forums/Uploads/Images/3642c449-9b40-4ff1-a7a8-2502.jpg
'58 Custom 300 Tudor
'56 Crown Victoria
'61 Starliner Z Code
'51 Ford Victoria
ScottY
Posted 16 Years Ago
Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)Normally aspirated (40 reputation)
Posts: 31, Visits: 204
You Bloody Ripper!!!!!!!!!!! They're a reality, as said many times, "THANKS JOHN" and i guess Jeff deserves a thank you also, can only imagine the headaches etc you've endured that we've not heard of, so a BIG tHANKS GUYS!!!! Though having said that, a very good coupla friends of mine did go down the same road a few years ago,and had some limited exposure to the ordeal, so i do understand a lil
"MY TWO BOBS WORTH!" (Twenty Cents AUD)
Y-BLOCKS ROCK!!!!!
ScottY
Posted 16 Years Ago
    Oh, and I just got off the phone with Jeff, and laid down my deposit/support!
Y-BLOCKS ROCK!!!!!
MarkMontereyBay
Posted 16 Years Ago
Posts: 733, Visits: 3.8K
I take some heat occasionally from the Early Bird purists. I keep mine the way I want it but don't do any modifications that can't be reversed with the original parts that I store in the garage. I don't intend on any body or frame modifications at all. Front disc brakes, sway bars, gas shocks, and cool wheels/tires with the right stance is good for me. I have MSD igniton now and Sanderson headers, a stock 4bbl manifold and Holley or a 573 Edelbrock with 3 94's ready to go. The Tbird clubs are about originality ala Amos Minter, etc. The values of early birds have stayed fairly flat over the decades due to so many that are left and unless you have an F bird that is righteously restored. Most of the people who have these cars are not interested in any performance or changes at all. I have my deposit in for the Mummert heads and will clean up and store the original heads (rebuilt with hardened seats) along with the manifolds, fender skirts, Coker white wall radials, etc. that came with the car when I bought it 15 years ago.
57 Black Tbird 312/auto
John Mummert
Posted 16 Years Ago
Posts: 919, Visits: 7.5K
My experience matched Frank's. I advertized in the CTCI news letter for a while and only sold a few 312 rubber rear main seals and neoprene valve cover gaskets.
The other end of the scale is the ratrod crowd. They don't care about originality but they also don't care about performance. Its still all about the look, it just isn't pretty. The engine just needs to be old and noisy.
I did notice in looking at the list of people making deposits that I could only identify 2 as being under 55 years old.
So it will be interesting see where the future interest will come from.
http://ford-y-block.com
Posted 16 Years Ago
Getting back to Frank's comments: I tend to be somewhat of a purist myself,( my 57 car is on a stock collector license plate, where mod's other than safety related are frowned on) however while I'm not a T. Bird expert, I have seen as recently as late last summer, what are apparently original or restored Birds, several in fact, that aren't original in the carburation & distributor areas. My point being that there indignation at using non original parts seems to be selective. And given that some parts are getting harder & harder to get, you would think that good repro parts would be welcomed by Bird owners & others. It strikes me that maybe some of these people need to give their heads a shake...
Oldmics
Posted 16 Years Ago
Posts: 710, Visits: 78.1K
John Mummert (5/28/2010)
Somebodys gotta show those young punks the future-Might as well be the  elder "Y" Block crowd Wink
Oldmics
Posted 16 Years Ago
John:
I think part of the age thing is that the post 55s are no longer making house and car payments and raising kids, so there may be a little more money available for their toys.  I'm sure glad that I'm no longer raising and educating my four kids.
