Ring gear and pinion
Posted By dbzach64C 15 Years Ago
dbzach64C
Posted 15 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Posts: 37, Visits: 746
Can any of you fellows give me a source for a ring gear and pinion set for a 1956 Fairlane Vicky? Stock differential which manual calls a Banjo Housing Hypoid. I'm looking for a 3.22:1 gear. Thanks
Wichita,KS
carl
Posted 15 Years Ago
Last Active: 4 days ago
Posts: 1.2K, Visits: 20.6K
i have what you need but shipping to you would probably be pretty high from ohio  Carl
dbzach64C
Posted 15 Years Ago
Carl. Thanks for the reply. I sent you a PM...I think.
Wichita,KS
carl
Posted 15 Years Ago
I sent you a pm but havent received a reply from you yet  Carl
KurtsVicky
Posted 15 Years Ago
First Time Poster
First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)
Posts: 3, Visits: 19
Help...if you found source for r&p for 56 (3.22) I sure could use a set as well....appreciate any help in that direction!  Thanks.. Kurt-Eagle Grove, IA
dbzach64C
Posted 15 Years Ago
I finally put in a 9" from a 1957 car. Simple bolt in with only change being to the length of the drive shaft. There may be someone out there supplying these stock gears but we couldn't find them in a timely manner.
Wichita,KS
KurtsVicky
Posted 15 Years Ago
First Time Poster
Zack--thanks for the info...do all 57 Ford and/or Merc models use 9" rearend as you describe...also did you use center section housing and bolt 56 axle housing to it or use entire rear axle assembly or.. thanks..Kurt
dbzach64C
Posted 15 Years Ago
As to what vehicles use what 9" rear end, I am no expert. The fellows here that answered my original question are the experts. I do know that they come in varying widths. All I can tell you for certain is that the rear end I used came out of a 1957 Ford passenger car. We used the whole assembly with my backing plates and drums. We used new brake lines and hoses but the wheel cylinders were near new so not replaced. I am lucky enough to have a friend who's really good at setting up rear ends. For my part, I got to do a lot of cleaning and painting of the new assembly.
Wichita,KS
KurtsVicky
Posted 15 Years Ago
First Time Poster
Zach--thank you for the post on rear end update on the 56!  I'm on the hunt now...Kurt
109569
Posted 15 Years Ago
First Time Poster
Last Active: 15 Years Ago
Posts: 2, Visits: 6
i have a differential out of a 56 ranch wagon, however im not sure of the ratio
curt
