Y block MSD Pro Billet
Posted By unibodyboy 15 Years Ago
unibodyboy
Posted 15 Years Ago
Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)Supercharged (128 reputation)
Posts: 118, Visits: 2.4K
This distributor ran for about 2500 miles, then the truck was parked over the winter. Had problems with backfiring when I got it back out, and thought (wrongly) that it was the distributor. Needed one that worked immediately, so I was forced to purchase another one. Sent the original back to MSD, which charged me to replace the cap and rotor... and told me it was fine. Long story short, I just want I have in it back. Shipping from 99163. $250.
My name is Greg and I am addicted to Y's.
55Birdman
Posted 15 Years Ago
Posts: 1.0K, Visits: 4.5K
Is  this one the 8383 ?
55Birdman Smile  Hickory NC
unibodyboy
Posted 15 Years Ago
Yes, it is a 8383. It still has the service tag from MSD on it. I can email pictures if you guys want.
55Birdman
Posted 15 Years Ago
Send some pictures to : wpccgrad@hotmail.com   Thanks
Ol'ford nut
Posted 15 Years Ago
Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)Supercharged (327 reputation)
Posts: 322, Visits: 1.2K
Wouldn't you need a MSD ignition control to make unit work? Now much are they?
Ol'ford nutCentral Iowa
56 Vic w/292 & 4 spd.
Posted 15 Years Ago
Last Active: 33 minutes ago
Posts: 6.1K, Visits: 442.6K
They don't need a box to work. It's kinda like a pertronix except in a completely new distributor that should be constructed better than stock. You just need to make sure the coil will play friendly with it.
Ol'ford nut
Posted 15 Years Ago
So buy a blaster coil and the wire plug to the coil and you are ready to go.
suede57ford
Posted 15 Years Ago
Posts: 216, Visits: 106.5K
My MSD had the mechanical advance was sticking as it needed lubed.   I could not get my timing to set right as it would either ping and idle too fast or run weak or idle too slow.   I twisted the mechanical advance by hand and found sometimes it did not spring back easlily.   A little lube on the inner pivit point and it has worked perfect since.
I use the MSD "High Vibration Coil" as it is able to mount horizonal( the standard Blaster oil filled is meant to point up) as the original coil   Remove the decal and a coat of Subaru Baja yellow on the top make the coil look stock too.  I did paint my MSD cap black to make it look more stock as well.
Pat Fleischman
