what yokes fit a T-85 overdrive transmission?
Posted By Mark T 16 Years Ago
Mark T
Posted 16 Years Ago
Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)Supercharged (93 reputation)
Posts: 35, Visits: 728
Here are all of the numbers on the transmission.
Trans case    T85C-1A     6-14 on a small plate riveted to side of case.
Tailhousing      R11-IE        7-12 on riveted plate
input collar    T-85C-6
Spacer between trans case and tailshaft   R11-8
Solenoid  1119779
Input shaft   1" diameter    6" long    10 spline
Output shaft  1.37" diameter   16 spline
Length of trans case, spacer and tailhousing  30 3/4"
H1952 stamped next to side cover on the machined surface.
Oldmics
Posted 16 Years Ago
Posts: 710, Visits: 78.1K
Mark
I should have also asked what sort of machine that this tranny is being installed into?
What we have here Tongue
is a 1956 O.D. slated for installation into a T Bird and some Mercurys.
The T Bird tranny was adapted from the Mercury.
The Ford part # for the yoke you need is
B6S4841-A
Hope this helps
Oldmics
ejstith
Posted 16 Years Ago
Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)
Posts: 494, Visits: 1.0K
I have 2 T-89's the truck version of the T-85. One has a spicer yolk and the other one has a slip yolk. Mine is broke but it's a 31 spline. It's good to know a C-6 will work. My main problem is I need a 6" input shaft as mine's 6 1/2. I think T-10 stuff may work too. I'd trade my 2 T-89's for one good T-85. One of mine is a short tail shaft and the other one is a long tail shaft. One is basically a parts tranny and the sun gears are shot ..
E.J. in Havana FL
Mark T
Posted 16 Years Ago
Thanks Oldmics.
I was going to install it in my '55 Sunliner but I've desided to use it in my '29 Model A Roadster behind a Y-Block.
What numbers indicate 1956?
Oldmics
Posted 16 Years Ago
Just the fact that the R11-1 E and also the R11-1 H were 1956 installs only for both the Merc and T Bird according to my documentation.
Oldmics
Mark T
Posted 16 Years Ago
Thank you very much...Mark
ejstith
Posted 16 Years Ago
In fact I'd trade them for a good T-86 that would bolt right in ..
E.J. in Havana FL
Daniel Jessup
Posted 16 Years Ago
Posts: 2.0K, Visits: 131.2K
To anyone interested, I just received a yoke (from a C6) for my T85 (passenger car) and it fits perfect.
ebay item #190296112754
Here are the numbers...
These are new slip yokes for Ford C-6 transmissions,
they have been sandblasted and sprayed with a rust preventive coating.
2-3-3131X
1310 Series u-joint
1.390" 30 based on 31 spline
1.685" ground hub diameter
1.150" counterbore
6 9/16" U-joint center to end
After a gift certificate from paypal, I paid a little less than $10 altogether. This is a nice piece.
Daniel Jessup
Lancaster, California
Mark T
Posted 16 Years Ago
I just check Ebay for a 16 spline yoke and found one for a Fordomatic, so I check my Ford Chassis Parts catalog to see if it would interchange with my Heavy duty 3 speed OD "T-85" and sure enough the Fordomatic and the heavy duty 3 speed have the same part number. can anyone verify this?
crenwelge
Posted 16 Years Ago
Posts: 512, Visits: 1.7K
What p/n are you talking about. 49-55 used the same Yoke except for the police intercepter. 56 was still 16 spline,but some used a Spicer joint and some a Mechanics. I have a Hollander for those years and they are pretty good in showing what fit in the real world.
Kenneth
Fredricksburg, Texas
