2010 EMC rules favor Y Blocks
Posted By RB 17 Years Ago
RB
Posted 17 Years Ago
Posts: 662, Visits: 16.7K
New rules are just out. Some changes from last year which actually favor us..
Dual plane intakes only on carbed engines
Carb size limited to 1 750-800 cfm
Hydraulic lifter only with a noted exception for the Y Block
RPM range is set at 2500 - 6500
The "Kaase Rule". The winner from 09 has to enter a different brand. Seems they are getting tired of Mr K's CHI headed 400s cleaning up every year.
The rules blantantly handicap carbed engines while giving injected motors a break.. Looks like they want some of the late model stuff to be more competitive.
Ted, do you think we can move up in the standings?
Posted 17 Years Ago
Last Active: 4 days ago
Royce.  I interpret the rules as allowing the mushroom tappets but not the solid lifters.  I read hydraulic lifters only.  Looks like I’ll have to ask the rules committee for a clarification on this.
Rules permitting, how about a 316 incher?  Last years heads and intake, possibly some smaller sized tubes on the headers with a 3” collector.  There’s time enough now to actually test some other heads.  Camshaft specs would have to be revisited though.  750HP Holley still seems to be the obvious choice.  This combination would definitely have a better score but as you point out, the rules for this year would appear to favor the EFI entrants.
If the rules do not allow the Y then how about a MEL engine?  I’m thinking roller hydraulic for the camshaft.  Unfortunately the rules also require a single carburetor and that’s a serious detriment for the MEL.  I was originally thinking along the lines of using the Super Maruder 3X2 setup but that’s not an option either based on the single carb rule.
speedpro56
Posted 17 Years Ago
Posts: 1.3K, Visits: 9.2K
Ted, Think YYYYYYYYYYYYYYYYYY BlockKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKiller 312BigGrin
-Gary Burnette-
Posted 17 Years Ago
Enter a Y and work with the Finn's on an injection setup!
46yblock
Posted 17 Years Ago
Posts: 1.2K, Visits: 7.8K
charliemccraney (12/13/2009)
An international Y entry.  Sounds very kool Cool   (and the MEL too).
Doug T
Posted 17 Years Ago
Posts: 563, Visits: 2.6K
Royce, Ted
Is there a link to the new rules? I would like to read them over.
Doug T
Posted 17 Years Ago
Last Active: 15 minutes ago
Posts: 4.6K, Visits: 39.4K
Try this one. http://www.popularhotrodding.com/enginemasters/0912em_2010_amsoil_engine_masters_challenge_rules_and_application/index.html
Tongue
John Mummert
Posted 17 Years Ago
Posts: 919, Visits: 7.5K
After reading the new rules they have again made an exception for the Y-Block lifters. Y-Block lifter is legal! RPM range of testing is 2500-6500 rpm. Dual plane intake for carburated engines. Carb size is limited as are valve lift (.650") and compression ratio (11.5:1). 280 cu in minimum.
Rules sorta make it look like they want the LS1 scruberlays to be more competitive. Pushing fuel injection but can't use 4 valve heads like some of the late model Ford cammers. 3 valve 5.4L Ford should be legal. Last years winner Kaase (Causey) can't run a Ford this year. Their explanation of what fuel injection manifold is legal is very confusing. Sounds like they want a throttle body on a dual plane 4bbl manifold. This will get some clarification later, I'm sure.
Ted, they correct to SAE which is quite a bit lower than the Standard we are used to seeing. That is why numbers were lower than you saw on your dyno.
http://ford-y-block.com
Y block Billy
Posted 16 Years Ago
Posts: 1.6K, Visits: 5.2K
Hmmm, Why can't Kaase run a Ford this year?? it is called the Engine Masters Challenge and he has proved that the Fords have been the master for many years.
This sounds like another scrubrolet conspiracy theory to me. They can't win so they have to change the rules, builder, whatever to look good in PHR press.
55 Vicky & customline
hotrodstude
Posted 16 Years Ago
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Last Active: 16 Years Ago
Posts: 5, Visits: 76
didn't kaase win a few years back with an olds ???
