Last Active: 9 hours ago
hotrodstude (1/31/2010) didn't kaase win a few years back with an olds ???Jon Kasse won with a Pontiac in 2005. This years rules calls for hydraulic lifters so a Y is will not be a player in this years competition. I do have an example of an early hydraulic lifter that is a mushroom design but I’d be hardpressed to try to use these for a performance application. I’ll post a picture of one of these lifters later this week as it’s quite simple in design but does still requires oil to be routed to the lifter galleries. Not impossible but simply not worth the effort.
RB
Visits: 16.7K
Ted, You believe that the current rules exclude Y-Blocks due to the hydraulic requirement? I noticed a specific reference gving exemption to our lifters in the new rules, does that not still apply?
I think some clarification about the lifters is required in the case of the Y. If they aren't going to allow it, then why even bother mentioning the Y in the rules? On one hand they say it must be hydraulic. Then they go on to say "Mushroom, ceramic, or composite lifters, for example “Schubeck” lifters are prohibited unless factory installed OEM item for engine used / Example: Ford Y-Block 312 engines." Are any of those available in hydraulic form for any engine?
ltman
Visits: 268
Ted if you cant run the y this year are you going to build a mel to run
86 mustang 351clt250/500r hybrid 4'' over swinger scr porting v2 reeds Q-pipe West virgina
The rules are clear in that only hydraulic lifters are allowed. For this year, mushroom tappets still remain disallowed in all cases except for the Y. If a Y can be made to work with a hydraulic lifter while retaining the mushroom tappet design , then it will be legal for this years competition. The 2010 rules are simply a rewrite of last years rules and the people writing the rules just do not realize that the Y did not come from the factory (for the mainstream engines anyhow) with hydraulic lifters so the rules exception for the Y concerning mushroom tappets is still there. I don’t have a problem with this as rules are rules. Was just glad that a Y was able to compete last year and show that they will hold together at 7400-7500 rpms while making respectable power numbers on pump gas and using cast iron oem heads. While there were two Ford 427 SOHC engines at the competition last year, you’ll likely not see them this year for the same hydraulic lifter rule restriction. That’s another engine that came from the factory with solid lifters only without the immediate capability for hydraulic lifters to be installed. Here are a couple of pictures of a mushroom tappet hydraulic lifter.
ltman (2/1/2010) Ted if you cant run the y this year are you going to build a mel to runRegarding a MEL (Mercury-Edsel-Lincoln) engine entry, I have considered one in the past for the EMC competiton and last year would have been the year to have entered it although the 3000-7000 rpm test range was not as favorable for this family of engines as the 2500-6500 rpm range that’s back in effect for this year. Unfortunately there’s not a decent single four intake available for the MEL engine which keeps the MEL engine from being a serious player in this kind of competition in a single four barrel carb only format but the oem iron heads are more than up to the task. Last years rules did allow multiple carburetion and the 1958 3X2 Super Marauder intake is very likely the best ever carbureted intake manifold made for this family of engines when used with the newer generation Holley 2V carbs. But multiple carburetion is not in the rules this year. This years rules also limit the carburetor throat size which will make the smaller engines much more competitive than they’ve been in the past. Said differently, large cubed carbed engines will not be as competitive this year and will be at a disadvantage due to the carburetor throat size limitation. Besides there not being a good single four barrel intake manifold available for the MEL engines, these engines are just too large in cubic inches to be competitive in this years competition with the carburetor restriction that’s in place.
How do we contact them to make them aware that a Y is not Hydraulic. If not for this year, we should be sure they know for next year. I think it can be a real competitor with the aluminum heads. Too bad 6's aren't allowed. I think a 300 would be neat.
speedpro56
Posts: 1.3K,
Visits: 9.2K
I'm with you Charlie, they should let the Y compete, it came with solid lifters and should be grandfathered in period.
-Gary Burnette-
Y block Billy
Posts: 1.6K,
Visits: 5.2K
are the 2nd generation Argentinian blocks made for hydraulics? also why not try some of their heads which are more small block ford design? I think we need to talk to that Argentinian Y block guru who has posted on this site before and get a fund going so he can ship up some parts that would really have the people scratching their heads as to what it is.
Larry D
Visits: 1.4K
Ted, Slovers casts an adapter for the MEL to use the newer 385 series intake manifolds. http://www.electronic-pr.com/pr/new_slo_001.html Or are adapters not allowed in EMC?
Larry D
Winnipeg, MB Canada Eh!
'58 Custom 300 Tudor
'56 Crown Victoria
'61 Starliner Z Code
'51 Ford Victoria
ltman
Visits: 268
Y block Billy (2/3/2010)
are the 2nd generation Argentinian blocks made for hydraulics? also why not try some of their heads which are more small block ford design? I think we need to talk to that Argentinian Y block guru who has posted on this site before and get a fund going so he can ship up some parts that would really have the people scratching their heads as to what it is. Thats a good ideal if they are hydraulics Ill give some for shiping Hears a link of them the pic of the block does look hyraulic but i cant read a word there saying LOL http://www.fordv8argentina.com.ar/292fase2.htm http://www.fordv8argentina.com.ar/v8292272.htm
