By RB - 17 Years Ago
New rules are just out. Some changes from last year which actually favor us..
Dual plane intakes only on carbed engines
Carb size limited to 1 750-800 cfm
Hydraulic lifter only with a noted exception for the Y Block
RPM range is set at 2500 - 6500
The "Kaase Rule". The winner from 09 has to enter a different brand. Seems they are getting tired of Mr K's CHI headed 400s cleaning up every year.
The rules blantantly handicap carbed engines while giving injected motors a break.. Looks like they want some of the late model stuff to be more competitive.
Ted, do you think we can move up in the standings?
By Ted - 17 Years Ago
Royce. I interpret the rules as allowing the mushroom tappets but not the solid lifters. I read hydraulic lifters only. Looks like I’ll have to ask the rules committee for a clarification on this. Rules permitting, how about a 316 incher? Last years heads and intake, possibly some smaller sized tubes on the headers with a 3” collector. There’s time enough now to actually test some other heads. Camshaft specs would have to be revisited though. 750HP Holley still seems to be the obvious choice. This combination would definitely have a better score but as you point out, the rules for this year would appear to favor the EFI entrants. If the rules do not allow the Y then how about a MEL engine? I’m thinking roller hydraulic for the camshaft. Unfortunately the rules also require a single carburetor and that’s a serious detriment for the MEL. I was originally thinking along the lines of using the Super Maruder 3X2 setup but that’s not an option either based on the single carb rule.
By speedpro56 - 17 Years Ago
Ted, Think YYYYYYYYYYYYYYYYYY BlockKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKiller 312
Enter a Y and work with the Finn's on an injection setup!
By 46yblock - 17 Years Ago
charliemccraney (12/13/2009) Enter a Y and work with the Finn's on an injection setup!An international Y entry. Sounds very kool (and the MEL too).
By Doug T - 17 Years Ago
Royce, Ted Is there a link to the new rules? I would like to read them over.
By MoonShadow - 17 Years Ago
Try this one. http://www.popularhotrodding.com/enginemasters/0912em_2010_amsoil_engine_masters_challenge_rules_and_application/index.html
By John Mummert - 17 Years Ago
After reading the new rules they have again made an exception for the Y-Block lifters. Y-Block lifter is legal! RPM range of testing is 2500-6500 rpm. Dual plane intake for carburated engines. Carb size is limited as are valve lift (.650") and compression ratio (11.5:1). 280 cu in minimum. Rules sorta make it look like they want the LS1 scruberlays to be more competitive. Pushing fuel injection but can't use 4 valve heads like some of the late model Ford cammers. 3 valve 5.4L Ford should be legal. Last years winner Kaase (Causey) can't run a Ford this year. Their explanation of what fuel injection manifold is legal is very confusing. Sounds like they want a throttle body on a dual plane 4bbl manifold. This will get some clarification later, I'm sure. Ted, they correct to SAE which is quite a bit lower than the Standard we are used to seeing. That is why numbers were lower than you saw on your dyno.
By Y block Billy - 16 Years Ago
Hmmm, Why can't Kaase run a Ford this year?? it is called the Engine Masters Challenge and he has proved that the Fords have been the master for many years. This sounds like another scrubrolet conspiracy theory to me. They can't win so they have to change the rules, builder, whatever to look good in PHR press.
By hotrodstude - 16 Years Ago
didn't kaase win a few years back with an olds ???
By Ted - 16 Years Ago
hotrodstude (1/31/2010) didn't kaase win a few years back with an olds ???Jon Kasse won with a Pontiac in 2005. This years rules calls for hydraulic lifters so a Y is will not be a player in this years competition. I do have an example of an early hydraulic lifter that is a mushroom design but I’d be hardpressed to try to use these for a performance application. I’ll post a picture of one of these lifters later this week as it’s quite simple in design but does still requires oil to be routed to the lifter galleries. Not impossible but simply not worth the effort.
By RB - 16 Years Ago
Ted, You believe that the current rules exclude Y-Blocks due to the hydraulic requirement? I noticed a specific reference gving exemption to our lifters in the new rules, does that not still apply?
I think some clarification about the lifters is required in the case of the Y. If they aren't going to allow it, then why even bother mentioning the Y in the rules? On one hand they say it must be hydraulic. Then they go on to say "Mushroom, ceramic, or composite lifters, for example “Schubeck” lifters are prohibited unless factory installed OEM item for engine used / Example: Ford Y-Block 312 engines." Are any of those available in hydraulic form for any engine?
By ltman - 16 Years Ago
Ted if you cant run the y this year are you going to build a mel to run
The rules are clear in that only hydraulic lifters are allowed. For this year, mushroom tappets still remain disallowed in all cases except for the Y. If a Y can be made to work with a hydraulic lifter while retaining the mushroom tappet design , then it will be legal for this years competition. The 2010 rules are simply a rewrite of last years rules and the people writing the rules just do not realize that the Y did not come from the factory (for the mainstream engines anyhow) with hydraulic lifters so the rules exception for the Y concerning mushroom tappets is still there. I don’t have a problem with this as rules are rules. Was just glad that a Y was able to compete last year and show that they will hold together at 7400-7500 rpms while making respectable power numbers on pump gas and using cast iron oem heads. While there were two Ford 427 SOHC engines at the competition last year, you’ll likely not see them this year for the same hydraulic lifter rule restriction. That’s another engine that came from the factory with solid lifters only without the immediate capability for hydraulic lifters to be installed. Here are a couple of pictures of a mushroom tappet hydraulic lifter.
ltman (2/1/2010) Ted if you cant run the y this year are you going to build a mel to runRegarding a MEL (Mercury-Edsel-Lincoln) engine entry, I have considered one in the past for the EMC competiton and last year would have been the year to have entered it although the 3000-7000 rpm test range was not as favorable for this family of engines as the 2500-6500 rpm range that’s back in effect for this year. Unfortunately there’s not a decent single four intake available for the MEL engine which keeps the MEL engine from being a serious player in this kind of competition in a single four barrel carb only format but the oem iron heads are more than up to the task. Last years rules did allow multiple carburetion and the 1958 3X2 Super Marauder intake is very likely the best ever carbureted intake manifold made for this family of engines when used with the newer generation Holley 2V carbs. But multiple carburetion is not in the rules this year. This years rules also limit the carburetor throat size which will make the smaller engines much more competitive than they’ve been in the past. Said differently, large cubed carbed engines will not be as competitive this year and will be at a disadvantage due to the carburetor throat size limitation. Besides there not being a good single four barrel intake manifold available for the MEL engines, these engines are just too large in cubic inches to be competitive in this years competition with the carburetor restriction that’s in place.
How do we contact them to make them aware that a Y is not Hydraulic. If not for this year, we should be sure they know for next year. I think it can be a real competitor with the aluminum heads.
Too bad 6's aren't allowed. I think a 300 would be neat.
By speedpro56 - 16 Years Ago
I'm with you Charlie, they should let the Y compete, it came with solid lifters and should be grandfathered in period.
are the 2nd generation Argentinian blocks made for hydraulics? also why not try some of their heads which are more small block ford design? I think we need to talk to that Argentinian Y block guru who has posted on this site before and get a fund going so he can ship up some parts that would really have the people scratching their heads as to what it is.
By Larry D - 16 Years Ago
Ted, Slovers casts an adapter for the MEL to use the newer 385 series intake manifolds. http://www.electronic-pr.com/pr/new_slo_001.html Or are adapters not allowed in EMC?
Y block Billy (2/3/2010)
are the 2nd generation Argentinian blocks made for hydraulics? also why not try some of their heads which are more small block ford design? I think we need to talk to that Argentinian Y block guru who has posted on this site before and get a fund going so he can ship up some parts that would really have the people scratching their heads as to what it is. Thats a good ideal if they are hydraulics Ill give some for shiping Hears a link of them the pic of the block does look hyraulic but i cant read a word there saying LOL http://www.fordv8argentina.com.ar/292fase2.htm http://www.fordv8argentina.com.ar/v8292272.htm
By aussiebill - 16 Years Ago
I think you,ll find the argy blocks are no different than normal and have solid lifters.
Larry D (2/3/2010) ...Slovers casts an adapter for the MEL to use the newer 385 series intake manifolds.As far as using Slovers intake adapter plates, as per the rules intake manifolds must be cast specifically for the engine. Retrofitting an intake manifold from another engine family by way of spacers or other modifications is not permitted.
It took three years to get the mushroom tappet rule amended so a Y could run. Regarding rules changes in general, at the conclusion of the competition, competitors are asked for rules changes or amendments in preparation for the next years competition. That would be the logical time to do a formal request. But there’s nothing preventing a mass influx of emails to the rules committee in the meantime stating the case that engines that came from the factory without hydraulic lifters should have some kind of exception in order to compete. Even suggesting duration and lift limits specific to these engines to help level the playing field with the hydraulic lifter competitors might help. The Ford Y-Block and the Ford 427 SOHC engines are good examples of solid lifter only engines. If you can think of any other American made V8’s that came only with solid lifters, then these should be brought up also. The email address for the rules committee is in the rules. Here’s the link to the current rules. http://krang.popularhotrodding.com/enginemasters/challenge/1001em_2010_emc_%20rules_1_28_10_final.pdf Be aware that the rules are in a constant state of being updated as questions arise so be sure to go to the EMC website for the latest rules.
e-mail sent.
Ted: Weren't the non SOHC 427 side oilers available only with solid lifters? The hydraulic 427s were top oilers, were they not?
By PF Arcand - 16 Years Ago
About Ted's question about other engines that were solid lifter. I doubt that anyone would consider entering one, but I believe the original Studebaker OHV V-8, introduced in Commanders in 1951, was a solid lifter engine...
Paul. Thanks for the tidbit regarding the early Studebaker V8. If that particular block or engine family was not later retrofitted with hydraulic lifters, then it would be like the Y and a solid lifter only engine. The FE’s when first introduced in 1958 were solid lifters but hydraulic lifter versions were introduced into that family of engines not long after the engines introduction.
Hoosier Hurricane (2/4/2010)
Ted: Weren't the non SOHC 427 side oilers available only with solid lifters? The hydraulic 427s were top oilers, were they not? The 427 FE sideoilers received hydraulic lifter capability in 1968 as well as the 427 service blocks manufactured after this point. Many of the aftermarket FE blocks also have hydraulic lifter capability regardless of the oil gallery layout so I doubt you’d see any sympathy from the rules committee on wedge headed FE’s that were solid lifter only on the blocks. Because FE’s were available with hydraulics, if someone wanted to use this engine as the basis of an EMC entry, they would be expected to simply use a hydraulic lifter capable block. Because the 427 SOHC was overhead camshaft, hydraulic lifter versions just didn’t make it into production so this engine is considered a solid lifter or solid tappet only design. There are some specific GM engines that also came with solid lifters but hydraulics were also available in the same family of engines so the ‘solid lifter only’ argument on those particular engines would not stick in this case either.
The SOHC is permitted, too. Certainly not hydraulic in any way. That indicates to me that they just aren't aware about the Y.
I was just reading on wikipedia, it says the cammer is the only engine ever banned from NASCAR. They need to check the history books.
By davis - 16 Years Ago
charliemccraney (2/5/2010) The SOHC is permitted, too. Certainly not hydraulic in any way. That indicates to me that they just aren't aware about the Y.
i think it was also banned by the NHRA too around 67?
Just sent my 2 cents worth into enginemasters concerning the yblock being included again.
By MarkMontereyBay - 16 Years Ago
Gary,
How or where does someone go to do the same as you. I would like very much to add a few cents to that cause.
Mark Hebard
Mark, not sure if I did it right or not but I sent the first email too questions@enginemasters.com and it came back as a failure , then I resent it too inquiries@automotive.com and so far it has not come back. Charlie, which email did you use to send your inquiries too? If I'm wrong then I need to resend it.
I sent mine to questions@enginemasters.com. So far I've not heard anything back.
Must be my hillbilly computer .
I sent off an email to questions@enginemasters.com a few minutes ago. Hopefully, EMC will have another Y block in the line up.
Mark Hebard
I resent mine to questions@enginemasters and it looks as if it went thru .
The EMC rules committee have modified the rules to allow engines that came factory equipped with solid lifters to compete alongside the hydraulic lifter entries. Here’s the excerpt from the Feb 11th rules revision that gets the Y back into the show. The letters to the rules committee have obviously been heard and the response was definitely positive. Hydraulic flat-tappets and hydraulic roller designs are only lifter type legal. Mushroom, solid, ceramic, or composite lifters, for example “Schubeck” lifters are prohibited unless factory installed OEM item for engine used / Example: Ford Y-Block 312 engines.
With this latest development, I’ll be working on a new Y combination for this year. Until the rules revision, I was looking at several other engine options. This would be a great place to showcase the aluminum heads and introduce them to the media. I'll add that there's another Y-Blocker out there that's sending in an application form for a Y entry. I'll not say who that is until they speak up. Two or more Y's in this competition would be exceptional.
Sweet!
By mctim64 - 16 Years Ago
Very nice indeed!
That's what we want to hear .
By Ketterbros - 16 Years Ago
Way to go Ted, Way to go all Y-Blockers, the more the merry..Competion makes for a better product.. Ted hope to see ya at the Spring Thaw..Denton TX.. Mesquite, TX
Way to go Y Blockers! persistance pays.
By yalincoln - 16 Years Ago
hi ted. i believe the early chrysler 318 wide block used solid lifters.i know they used adjustable rockers. do you have the performance data on last years y entry? i must have mised it. i've been without a computer all winter. it's good to be back, got a lotta catchin up to do, thanks, wayne.
Good to see you back Wayne. The results of the 2009 EMC competition have already been published in Popular Hot Rodding and the Engine Masters magazine which both did the Y movement justice. The Engine Masters magazine may still be on the newstands but the Popular Hotrodding piece was awhile back. Here’s a link to a thread regarding last years EMC competition. http://www.y-blocksforever.com/forums/Topic33114-5-1.aspx And here’s the link to the first article that was published in the Y-Block magazine. Y-Block Magazine 2009 EMC article
