Rocker arm geometry
Posted By Ted 17 Years Ago
I still have to replace the king pins.  Other than that, it's looking good for Columbus.  I plan to start on the king pins this week.  That should give me some time to put a few miles on everything and make sure it is good to go.
Ted actually has a tool for measuring travel across the tip.  Aside from that, blue the tip of the valve, run the valve through a few cycles and I measured the pattern with a caliper.  You can see the change if it is really bad but as you get closer to ideal, it becomes more difficult to tell by eye.
After driving it a couple days this week, it does seem like it might be a little more zippy at lower revs, but nothing like the improvement at high revs.  It sounds different, too.  Good different.
For those who are curious, I made the shims out of a strip of 3/4" wide 6061 aluminum.  I marked the center of the strip and allowed 1/8" between to cut them apart.  A spare rocker stand and transfer punches were used to mark the holes.
I then drilled them.
Cut them out and shaped them.  Some came out a bit wonky but it's not really a problem - I just make sure a good one is in the oil hole position.
New Smith Brothers pushrods next to an old one for comparison.  Because the rocker rotates toward the valve as the stands are raised, pushrods longer than the change in shim height are required.  These are 8.362", so a 1/4" change in stand height required about a 3/8" change in pushrod length in this case.
Everything in position.
and installed
I went with valve covers from spotlitekustomaccessories on eBay.  The taller covers required that I move the coil which required that I change the fuel line routing - both things that I had been wanting to do but it wasn't really that important.  With the old coil position, I could not remove the valve cover with the coil in place.  I can remove the valve cover in the new position and a raised base 14" air cleaner should fit, if needed.  The fuel lines just look less cluttered and more aesthetically pleasing now, I think.
Before
After.  Breathers will be used until I've had a chance to do some spacer testing.  Once I choose a spacer, PCV will be refitted.  The rubber fuel hose will be replaced with a hard line once I choose a spacer.
A bracket to ensure that the regulator stays in place, even though it is mounted right on top of hard fuel fittings.  Left plenty of room for a wrench to get at the fittings.
Posts: 1.9K, Visits: 195.0K
Charlie,
I really appreciate the detailed info.
Very nice work. Looks really good.
Rowen
Posts: 435, Visits: 29.3K
Charlie, I just couldn't not read this thread and say something about that gorgeous engine! This entire conversation is WAY above my level of expertise. Having said that, I can only hope that MY 292 turns out half as well as your power plant! I pick up my motor next weekend and will post pics and as much info about it as I can. I will be picking as many of the BIG brains on this site as I can when the actual build starts. My son- in-law is a mechanic but has NO y-block experience. It already has some of John mummerts parts installed, pistons, cam, timing set and a few more. I will need to get some more info about it before I can ask any "intelligent" questions. I am hoping to find someone reasonably close to mentor my son and I during this build. I hope that between that and folks like you, Ted, and others on this site that my engine will be something to be proud of. I've had my stock 55CV in 6 shows so far this year with (at this time) 3 more lined up. From what I've seen, Y block power is rare in these parts and I am truly looking forward to showing the people something unusual, beautiful and powerful. Man, I know I'm long winded but every time I log on, I just get more enthusiastic about my project. Anyway, I say Nice Job Charlie!! And thanks for the vicarious insperation. Rowen
Rowen
55CV
Woodland, Ca
