Newbie from OZ
Posted By yblock32 16 Years Ago
yblock32
Posted 16 Years Ago
Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)
Posts: 32, Visits: 592
Just a quick hello from a newbie from Australia. Great site ! My current ride is '32 Tudor powered by a triple carbed 272
backed up with a FMX auto. Great fun to drive & creates lots of interest when people realise what's in it . Y-Blocks down here were the back bone of hot rodding during the 60's & 70's and are now seeing a resurgence in popularity.
Will post somes pics as soon as I can.
IMG_5631.jpg image by yblock32 yblock32
mctim64
Posted 16 Years Ago
Posts: 2.4K, Visits: 5.0K
Welcome yblock32, we have a lot of "Aussies" here and could always use another. Tongue
pcmenten
Posted 16 Years Ago
Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)
Posts: 375, Visits: 1.1K
Welcome. I've always been impressed with the work that our friends from down under do.
I'm curious to know the details of your FMX conversion; flywheel, converter, etc.
Best regards,
Paul Menten
Meridian, Idaho
aussie-y
Posted 16 Years Ago
Turbocharged (56 reputation)Turbocharged (56 reputation)Turbocharged (56 reputation)Turbocharged (56 reputation)Turbocharged (56 reputation)Turbocharged (56 reputation)Turbocharged (56 reputation)Turbocharged (56 reputation)Turbocharged (56 reputation)
Posts: 48, Visits: 6.0K
g,day there yblock 32 glad to have another aussie on board this is a great site about the mighty y block the only motor to power a hot rod. best sounding motor on this planet.
http://www.y-blocksforever.com/forums/Uploads/Images/87bb8b10-6d67-4f43-8c99-4d39.jpg    RAY. Y,S ALWAYS
LON
Posted 16 Years Ago
Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)Supercharged (604 reputation)
Posts: 523, Visits: 3.7K
Welcome to the site . What part of the country do you live ??? Always good to have another Aussie  on the team. At one stage we were almost being out numbered by the Canadians ???
Can you imagine that ?? An Aussie being beaten by a Canuck ?? Almost unthinkable ??
Lon
yblocksdownunder
yblock32
Posted 16 Years Ago
pcmenten (3/29/2009)
Paul , my conversion was fairly simple in the end .A friend and I found a rotted out '56 Customline and removed its trans, convertor,drive plate and bellhousing. Two top mount holes have to be drilled & tapped into the bellhousing to accept the FMX (lower ones are the same ). I re-rivited the spring steel dampeners to the 1/4" thick drive plate as they had come loose.I then had a local Auto-Trans  repairer modify the '56 convertor by cutting off the original pump drive and fitting an FMX one.This was the only problem I had with the conversion as he didn't get the length right first time. I then had them go through the trans as it needed new clutch pack etc. Trans was a unknown "swap meet special" , but had a shift kit fitted sometime during its life and surprises people when they first ride in the car ( have later found out that the trans was originally behind a hot 351c ). The last mod was converting a Mopar ( cause I liked the look of the shift lever ) shifter to work like a Mustang shifter , but mounts direct to the trans.   Thanks for your interest -  David
yblock32
Posted 16 Years Ago
LON (3/30/2009)
Lon
Lon, I'm from Shepparton
yblock32
Posted 16 Years Ago
aussie-y (3/30/2009)
I'll second that !!
Y-Block - 1
Flathead - 2
FE  - 3
LON
Posted 16 Years Ago
Hey yblock32 ,
I have a 272 +FOM in an "A" Model roadster with 4.11 Mainline diff . The Vicky has a 301 Y block with a FMX and stock 3.22 diff. Lastest project is a 58 F100 fited with a Jag XJ6 front end ..It will have a Y block also .Still not sure on gearbox yet .Toploader,T5 or FMX.???
Is your 32 on the road ??
Lon
yblocksdownunder
yblock32
Posted 16 Years Ago
LON (4/1/2009)
Hey yblock32 ,
Lon
Yes Lon , my Tudor has been on the road since Dec. 2007 as has done about 9000 kms since.
