Truck parts for sale
Posted By 55Birdman 16 Years Ago
55Birdman
Posted 16 Years Ago
Posts: 1.0K, Visits: 4.5K
Charlie the pump has a flat steel cover. Gerotor ?
55Birdman Smile  Hickory NC
Posted 16 Years Ago
Last Active: 11 hours ago
Posts: 6.1K, Visits: 442.3K
Oh, oops. I had them backwards. I'll send an e-mail.
Posted 16 Years Ago
Posts: 7.4K, Visits: 205.4K
A flat steel cover on the oil pump will make it a gerotor (gerorotor) style while a thicker cast iron cover with a couple of knobs or protrusions on it will be the spur gear style of pump.  Gerotor pump housings are aluminum when supplied by Ford but were in cast iron when made by the aftermarket companies so the housing material will not be definitive in identifying which style pump is being dealt with.
55Birdman
Posted 16 Years Ago
magnet sticks to shaft only the case is aluminum
Posted 16 Years Ago
If it's iron, it's the one I want.  Got a magnet?
Doesn't really matter if it works.
55Birdman
Posted 16 Years Ago
Its has some weight but looks like aluminum. May have some iron gears inside. My guess would be iron.
Posted 16 Years Ago
Is it aluminm or iron?
55Birdman
Posted 16 Years Ago
Charlie, The number on the pump is C1AE6604A. The number in my book is C1AE6600A. I'll have to take the cover off the pump and do a visual unless someone knows the part number for the gerotor. I looked in my books and I cant find a number. Will keep you advised .
55Birdman
Posted 16 Years Ago
Dont know will check.
Posted 16 Years Ago
Is it a gerotor oil pump?
