Truck parts for sale
http://forums.y-blocksforever.com/Topic20462.aspx
By 55Birdman - 16 Years Ago
I have some truck parts from a 62 truck 292 engine.
Valve covers- dirty but good- starter unknown cond-generator unknown, timing cover good,front motor mount, pulley ,C heads with rockers very good, oil pump unknown have shaft. flywheel .Bellhousing. Truck was straight drive, also have all the bolts from tearing the engine down.
I am in NC can ship via any carrier you need. I am open to any price as I aquired these for free and dont need them. sold generator and power steering brackets. NO DIZZY sorry
Also have set or 55 Bird heads off my bird with rockers. worked perfectly when took off ,no pushrods. bird is my daily driver and I installed a set of 113 heads I found and dont need these. 100 bucks . e-mail me at
my1955tbirdman4ever@hotmail.com
Is it a gerotor oil pump?
Dont know will check.
Charlie, The number on the pump is C1AE6604A. The number in my book is C1AE6600A. I'll have to take the cover off the pump and do a visual unless someone knows the part number for the gerotor. I looked in my books and I cant find a number. Will keep you advised .
Is it aluminm or iron?
Its has some weight but looks like aluminum. May have some iron gears inside. My guess would be iron.
If it's iron, it's the one I want.  Got a magnet?
Doesn't really matter if it works.
magnet sticks to shaft only the case is aluminum
By Ted - 16 Years Ago
A flat steel cover on the oil pump will make it a gerotor (gerorotor) style while a thicker cast iron cover with a couple of knobs or protrusions on it will be the spur gear style of pump.  Gerotor pump housings are aluminum when supplied by Ford but were in cast iron when made by the aftermarket companies so the housing material will not be definitive in identifying which style pump is being dealt with.
Oh, oops. I had them backwards. I'll send an e-mail.
Charlie the pump has a flat steel cover. Gerotor ?
