Wanted Solenoid T-85/89
Posted By ejstith 17 Years Ago
Carls56
Posted 16 Years Ago
Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)
Posts: 25, Visits: 55
Hoosier Hurricane (12/31/2008)
No, they won't bolt into anything else.  Bolt pattern is different, many have a fixed yoke on the back which requires a slip joint in the driveline.  The OD parts are interchangeable throughout the BW line.  I once got a pawl that was NLA available from Ford, the local AM dealer had it in stock.  'Course the AM dealers are gone now.
John
That is the one I got.Rolleyes  He said it was from a 57 studebaker truck.Oh well,maybe I could trade for something.
Posted 17 Years Ago
Last Active: 5 hours ago
Posts: 3.7K, Visits: 322.2K
John
ejstith
Posted 17 Years Ago
Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)
Posts: 494, Visits: 1.0K
Hoosier Hurricane (12/16/2008)
EJ:
Forgot to mention in previous post, Studebaker probably sold more Warner overdrives than anyone else.
John
John, is the bolt pattern the same as a Ford?
E.J. in Havana FL
ejstith
Posted 17 Years Ago
How much?
E.J. in Havana FL
crenwelge
Posted 17 Years Ago
Posts: 512, Visits: 1.7K
This one will work. http://cgi.ebay.com/ebaymotors/Overdrive-solenoid-12V-Borg-Warner-GM-Delco-58-59-60-61_W0QQcmdZViewItemQQcategoryZ34206QQihZ019QQitemZ290284866829QQrdZ1QQsspagenameZWDVW
Kenneth
Fredricksburg, Texas
Carls56
Posted 17 Years Ago
     I just bought a t-85? from a guy that said it was removed from a studebaker truck.I thought I might be able to use it on my y-block.
     Earlier tonight I was doing a search on the trans and saw a thread where a guy was looking for solenoid.
    One of the replies said,The seal usually leaks and you can take the solenoid off ,clean it out with brake and clean ,and replace the oring,it will usually work.
   I have not tried it,but it might be worth a shot.And Merry Christmas to everyone.
carl
Posted 17 Years Ago
Posts: 1.2K, Visits: 20.6K
i sent you a pm with the cost  Carl
ejstith
Posted 17 Years Ago
And how cheap would that be?
E.J. in Havana FL
carl
Posted 17 Years Ago
I forgot to mention that the 56 is NOS (new)  Carl
carl
Posted 17 Years Ago
I have a couple of overdrive solenoids  on has a 63 part number but the other one is a 56 number  B6A-6916-A i think the 56 is probably what you need but i not absolutly sure.I is not going to be cheap but less than Councours   Carl   Ohio
