Posts: 1.9K,
Visits: 195.0K
I believe you, I’m just surprised.
Half-dude
Last Active: 6 Months Ago
Visits: 11.3K
I'm just about finished with the conversion, I ran into a snag with the turn-signal and tail-light bulbs. The bulb used are 1154s double-filament bulbs that I still see on the shelves today at the autoparts store. I just picked up 2 2-packs from the store and put them in my car. I seems like by default the bulbs are shining the brights when the running lights should be on (like you have the brakes held down) and the blinkers do nothing. At first I thought I wired my new flasher wrong, but it was clicking and the indicators were flashing on the dash. I pulled the front blinker bulb out and flipped it over and stuck it in and then the blinker worked, but of course the bulb wont stay in that way because the little nubs on the sides are keyed. What gives, are the newer 1154s wired in reverse compared to the older ones? Anyone else run into this issue?
Visits: 498.2K
It looks like you got the wires at the bulbs reversed . Switch wires and see what happens.
Half-dude
Visits: 11.3K
The thing is I didn't touch the wires for the lights, the only thing I did was install a new flasher. It's literally the two wires off the old one and two onto the new one. : o I tested it with the old bulb (didn't burn out hmm) and it's doing the same thing, so yeah it's not the bulb..damn.The kit I got from Vintage Auto Garage gave me this flasher, said to not use the P tab if not needed but that it should work: https://truck.upauto.com/led-flasher-12v-3-terminal-90651But this is all I did, so I'm confused why it's not working right: NOTE: yes I did connect the ground wire on the flasher and verified it's a good ground.
Posts: 2.0K,
Visits: 306.6K
Is this the flasher PN you used?  For use with all vehicles that are changed to LED tail lights and front turn signals.
Half-dude
Visits: 11.3K
It is, but also I didn't choose the part it just came as part of my 12v convo-kit. The same kit optionally sold replacement 12v light-bulbs (non-led). I thought the same thing as you, but why would they sell it in the kit if they were selling you light bulbs? I figured it must work for both, is that not the case?
Posts: 2.0K,
Visits: 306.6K
This usually is simple.You DO NOT need to switch your headlight switch, the brake light switch, headlight high beam switch, the headlight circuit fuse, and the turn signal fuse. They are fine for a 12v system. You will want to change your turn signal flasher for a 12V unit. Just take the old 6V one in and match up a 12V replacement. The wires connect to the similarly labeled terminals on the 12V flasher. Now just change out the bulbs. Look closely at the sockets and make sure they are clean and not corroded. Usually, you can just take one of each type of 6V bulb you have and find its 12V equivalent. You want to pay attention how the base is made and the size of the bulb. Sometimes you may have to change out the pigtails in a socket to make them work. Pigtails are the bottom terminals that push into a socket and have the wire ends. Or you may just change the entire socket.
SOURCE - https://classicautoadvisors.com/2021/07/12/classic-car-6-volt-to-12-volt-conversions/
All you need is a 1956/ 2-BLADE 12V flasher. Take your 6V in with you to ensure correct pin-out.
Posts: 2.0K,
Visits: 306.6K
" ... but why would they sell it in the kit if they were selling you light bulbs? I figured it must work for both, is that not the case?" You have to be very careful of vendors these days. They are usually out for quick bucks offering cheap off-shore service parts.
Half-dude
Visits: 11.3K
Thanks for that conversion table, that was a big help. I actually got the issue figured out, it wasn't a wiring issue it was the bulbs. I bought new 1154 bulbs not knowing 1154s were still 6v. I guess it's stupid to think so but I actually thought all bulbs sold for cars were 12v now. I went ahead and bought some 2057s and everything works fine now. Thanks for the help guys.  This should be my last ever question on this thread, but are you guys aware of what these are under the dash? They have power leads going into them but I can't tell if the little blocks there are just junction posts or actually some kind of relays, they don't show up on any of the schematics I can find. Maybe they're just hookups for accessories like the clock and such? I'm wondering if they might be a good spot to hook up my voltmeter to.
Posts: 2.0K,
Visits: 306.6K
I guess it's stupid to think so ... There is no stupid, only learning. Those are either relays or circuit breakers. You would have to trace the wiring to see where it goes.
