Visits: 9.3K
On my 56 Ford-312-----I recently installed a new Bendix from Concours, like in November. Have not used it alot-- It fell apart. The pin that goes in the end was actually on the floor under the car, I have not found the end plate washer yet. . Did I get a defective Bendix? Any suggestions on what might be causing this? Thanks.
Visits: 206.1K
Sounds defective. Is the spring broken?
Visits: 9.3K
Everything is intact except the end ring is gone. We attempted to build one from the two I have. We cut the fist one apart to get the end ring off It would be impossible to put this ring on-how did it come off. It had to break, why. Have not looked at all of the teeth, can see one side from the inspection plate. Those that I can see are good. I bought this from Concours Parts. Is there a better source--like themanufactuer? Thanks. for the reply. Harold
Last Active: 3 Weeks Ago
Visits: 113.5K
Visits: 6.4K
This is the reason that I always try to avoid buying new reproduction parts. An NOS, NORS or even a good used part is always better than a made-in China or Taiwan reproduction part.
Visits: 9.3K
Ordered it-thanks for finding it.
