Starter Bendix
http://forums.y-blocksforever.com/Topic167825.aspx
By Skyliner57 - Last Year
On my 56 Ford-312-----I recently installed a new Bendix from Concours, like in November. Have not used it alot-- It fell apart. The pin that goes in the end was actually on the floor under the car, I have not found the end plate washer yet. .  Did I get a defective Bendix? Any suggestions on what might be causing this?
Thanks.
By Ted - Last Year
Sounds defective.  Is the spring broken?
Everything is intact except the end ring is gone. We attempted to build one from the two I have. We cut the fist one apart to get the end ring off
It would be impossible to put this ring on-how did it come off. It had to break, why.
Have not looked at all of the teeth, can see one side from the inspection plate. Those that I can see are good.
I bought this from Concours Parts. Is there a better source--like themanufactuer?
Thanks. for the reply.
Harold
By FORD DEARBORN - Last Year
https://www.ebay.com/itm/176780491492?_skw=ford+y+block+starter+bendix&itmmeta=01JJHF6KZ6PDYKN0CYYTB5MB8B&hash=item2928f03ae4:g:~HEAAOSw8odnft-S&itmprp=enc%3AAQAJAAABAHoV3kP08IDx%2BKZ9MfhVJKnZq%2BSi7CU9VJyjjonOFQBqdydmoMBIWnkAzQx8xT4nTAkfhe6HrZmjJrwVta1HhBXAKnm58%2BZFhAfIDbWxOHJhFy9LPCsTi1XQSs56Bl41V%2Fhm7DjjyEqzUp3Fr4f0eYiPoVc0CV8e8SYQeNONhi4ni8hnviqyxcHJjtS%2BMDu%2BDuMmtaBZkw6ArqRv%2F8PDNs2ZpspW%2FmtPZpJge30hMas94iiOB3LtKSrlaHY%2F6HYRDss2HMFbTFXRnh%2Bp4qHjZ7FU7V%2FlZf3nYFMCEwWBKt7yNxZnrVI376CFxgcvprNvhH2yHORr1gkTDjnPbu1ML%2B0%3D%7Ctkp%3ABk9SR-C_mq-UZQ        I'm not too good with this thing so hopefully the link for a NOS Ford starter drive/Bendix will open. I know nothing about this particular offered part of seller.
By alanfreeman - Last Year
This is the reason that I always try to avoid buying new reproduction parts.  An NOS, NORS or even a good used part is always better than a made-in China or Taiwan reproduction part.
Ordered it-thanks for finding it.
