Visits: 1.5K
I removed the tank completely again to check out the threads on the tank. I will be putting the tank up with the straps barely secured so I can move the tank around, ensuring proper alignment
Visits: 1.5K
Threads on fuel line fitting and in tank are both good. Verified using correct nut and bolt. Spent half hour trying to screw together and still spins without biting. Lubed both threads , moved tank and line around, verified angle bolt goes into tank. Frustrating
