comrade-paul
Last Active: 15 Years Ago
Visits: 190
Thanks guys. I just bought some Comma Classic 20/50 and according to the bloke in the auto parts shop iot is meant for older style engines and includes some anti shearing agent to aid the flat bottomed tappets. Is he lying to me? I can punch fairly hard.
Picture taken in 1960. Funnily enough it still looks like this!  1959 Mercury Monterey 312 Y Block. NORFOLK, ENGLAND, UK.
Posts: 3.0K,
Visits: 8.7K
Paul, Don't think we have that brand Stateside, I've never seen or heard of it here. What you're looking for is Zinc, or a zinc substitute. Diesel oils have it, some racing oils or additives like Lucas (no, NOT the Prince of Darkness) or STP, also have it or a substitute.
46yblock
Visits: 7.8K
I bought 2 cases of round can Chevron 10W40 grade SE,SF recently, not being able to pass up .50 per can. Would it work well in a Y?
Posts: 3.0K,
Visits: 8.7K
Mike, I think the SE is ok, You can tell by the designation. Or you could if you can remember which is which, and I forgot! They changed the designation after they removed the zinc.
46yblock
Visits: 7.8K
Frank, The cans show"SE,SF", apparently a transition grade. They are the round cardboard cans with a top zip seal. Mike
marvsmerc
Visits: 415
Does anyone use Amsoil 20/50 ? I know its expensive but they advertize it for flat tappets, & older vehicles & state that it has a heavy treatment of Zinc ? There is a distributer in my town that stated all Amsoil oils have zinc in them, but I didn't find this online. They also state to change every 25 g's or one year. What happens to the oil if it is sitting in your engine for a year with no condensation, for example if stored in a heated garage? Thanks, Mike
Posts: 3.3K,
Visits: 238.8K
Comrade Paul: Because the brands in the U.K. don't match up with N. American oils, it's difficult to make a recommendation. However, a question occurs to me, considering the cool climate there, why are you using such heavy viscosity oil in a new rebuilt engine? Are the clearances on the loose side? It seems like it might not be the best decision. However, I could be wrong about this.. others might want to comment.
HT32BSX115
Visits: 24.4K
46yblock (9/27/2008) Frank, The cans show"SE,SF", apparently a transition grade. They are the round cardboard cans with a top zip seal.
MikeThat API designation (SE/SF) is an obsolete rating, replaced back in 1988. Here's an API chart that gives a chronology of the classifications. http://motorcycleinfo.calsci.com/API.html Consumer Reports did a widely acclaimed oil test back in the 90's that indicated that 10W40 might not be the best choice for some engines. ( for example, my 1986 Ford 6.9L diesel truck manual instructed "Do Not USE 10W40 as it may cause engine damage") I don't know why Ford recommended against 10W40 for that engine. Maybe early 10w40 oils had a excessive amount of VI improvers. I use Shell Rotella 5W40 or 15W40 in everything now Because "Wally World" beats everybody in price. (although Schucks/Checker/Kragen will beat them now) (except the airplane.....that gets Aeroshell 100) I'll also add that since most new engines are "roller" engines, they're getting away with reducing the zddp. That doesn't help us much with our flat tappet Y-blocks. I think we'll be able to get 15W40 oil for older diesel engines for quite some time. I suppose the "snake oil" salesmen will always have an additive ready to suck money out of our wallets.... I'll always be pretty skeptical or their claims unless someone like Crane Cams, Comp, or Isky tests them and warrants their cams with it....... DON'T USE API SA in ANYTHING. Cheers,
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1955 F-600/272/E4OD// Disclaimer: No animals were injured while test driving my F-600 except the ones I ran over intentionally!
--------------------- This post was created using OpenSuSE Linux x64 and Firefox
2DRHRDTP57
Visits: 1.8K
Caterpillar DEO (Diesel Engine Oil) available in 15w40 (and 10W30 in selected countrys) I downloaded this sheet on the Cat oil today at work it is a Gasoline rated SL oil and has 0.146 of zinc which I think = 1460 ppm http://www.cat.com/cda/files/199221/7/pehj0059-02.pdf Our oil lab guy says its good for flat tappet Y blocks, being Cat its available worldwide too for all Y blockers and it comes in 1 Gallon or over here in my paddock 5 litre packs. 15w40 DEO 5 Litre Pack part number 3E9901 or 248 7518 for a 1 US gallon pack http://catmsds.cat.com/MSDSSearch/servlet/cat.cis.ecs.msdsSearch.controller.SearchResultsDisplayServlet?MSDSNO=8962&LANGUAGE_CODE=en_US&searchString=MSDSNO I'm going to give it a run in my rebuild, cheers
1957 ________________ Ford
\___((_______________))___/
(@)________V__________(@)
[________I_____I_________]
__[__]__ o_______o___[__]___
Y Blocks, The New Flathead!
HT32BSX115
Visits: 24.4K
Recommended Use Caterpillar.
• Cat earthmoving, commercial, marine* and on-highway truck diesel engines
• Low-emission diesel engines including Cat engines with ACERT® Technology
• Heavy-duty diesel engines made by other manufacturers that recommend API CI-4
PLUS, CH-4 or CG-4 category oil (See “Typical Characteristics” on page 2 for
more information)
• Automotive gasoline engines that require API SL category oils
* Excluding 3600, C280, 3126 and 3116 MUI Marine and MaK diesel engines. The 3116 and 3126
MUI Marine diesel engines with closed crankcase ventilation systems should use Cat SAEO™. I guess you could say it's an SL oil... It's a diesel rated oil that that also happens to meet SL standards (too). Because it is a CI-4 PLUS rated oil it will have lower zinc than earlier diesel type oils. I hope no one thinks that Cat actually "makes" this oil using their own secret lab with their own mad scientists  !..... They've re-branded Chevron Delo, Mobil Delvac, Shell Rotella or similar 15W40 and/or 5w40 oils into their own marketing network. FORD, GM, IHI, John Deere, VW, Mercury Marine, Volvo, etc, etc, do this and just about every other automotive manufacturer too, as have the oil companies with gasoline, diesel fuel and oil for many years.... They would LOVE for their customers to buy all their oil from them. It's just another profit center. Cheers, Rick (I love Christchurch! been there many times in a USAF C-141 over the years......)
