B-rad
Visits: 1.5K
I'm getting closer to starting my 317 for the first time since the rebuild. I'm trying to find out how to get it primed with oil before cranking it up. I did swap out the dizzy and oil pump for a newer setup so I can run a different carb. I read somewhere to fill it with oil and spin it around on the stand to get oil everywhere. I'm thinking that's all it will do, get oil everywhere. I know there's a way to spin the dizzy or oil pump somehow to move the oil from the pan thru everything. Just don't know how. I just got the tranny back from the shop. They had it for almost 18 months but it's done. Should I hook the tranny and engine together before I prime it or doesn't that matter? Since it will still be a few weeks away, I should wait until just before starting it before priming it, right?
Posts: 1.4K,
Visits: 2.0K
If you're starting it for the first time after a rebuild, you'll want to run it at 2000-2500 rpm for at least 20 minutes to break it in. I'm not familiar with the 317, but if the oil-pump drive will remain upon removing the distributor, you should be able to drive the pump with a drill. If you have a well-equipped engine run stand and are able to keep the engine from overheating during run-in, you don't need to attach the transmission. Your other option is to install the engine and transmission, and then fire it up. If everything else is as it should be, take it for a test ride after break-in, but don't stray too far from home.
FORD DEARBORN
Last Active: 4 days ago
Visits: 113.5K
I'm not familiar with the 54 Lincoln car but if the starter ring gear is part of the torque converter assembly, then you will need that in place for the starter motor to function. Other folks will chime in but l would want the trans attached just to support the heavy converter. If/with the trans being attached, adding fluid will also be part of the startup procedures. I'm familiar with the air cooled FOM's and thinking your trans convertor will be similar?
Joe-JDC
Visits: 23.3K
Which ever distributor drive you have, slot or hex, you can spin the oil pump in the direction of distributor rotation, and prime the engine. It is also helpful to be able to rotate the crankshaft at least one revolution to allow oil to reach all of the different passages in the crankshaft mains and rods and up to the rocker arms. Keep the oil pump priming until you see oil coming out of the rocker arm/shafts at all valves. It does not need the transmission attached to do this. Joe-JDC
Posts: 2.0K,
Visits: 306.6K
If you have retained the HYDRA-MATIC, the RG is on the flywheel. If you turn the CS while priming the oiling system, it may wipe the assembly/break-in lube off the cam and lifters. * Along with if the fuel is not primed or ignition lead not set correctly to allow fast start, extended cranking will wipe the cam assembly lubricant or if the oiling system is not primed will have a dry cranking period on hard start. I would do all of this after the engine/trans is mounted in the car. Unless you have a break-in stand, starting one on an engine stand might prove disastrous (IMO of course). Don't forget the blended break-in oil (no additives).
Visits: 498.2K
If the 317 had the same type of shaft set up as a 292/312, you can use a speed wrench as well as a drill (reverse?)to prime the engine. That is how I have primed mine. (speed wrench)
B-rad
Visits: 1.5K
Using the grill, how does it attach to the distributor shaft?
pintoplumber
Posts: 1.0K,
Visits: 164.5K
I’m guessing you have the tang drive distributor. Maybe you could cut off an old screwdriver that would fit in your drill and cut a slot in the tip that could fit on the drive?
Dennis in Lititz PA
B-rad
Visits: 1.5K
I have the newer drive shaft, can't remember if it's hex or slot. Found out that I will need to remove the distributor and connect directly to the oil pump shaft
FORD DEARBORN
Visits: 113.5K
The hex oil pump driveshaf is 1/4". I use a 1/4 drive, 1/4" deep socket attached to an extension driven by a reversed drill motor. Just be very careful after priming to not loose the socket when pullig it out of the engine.
