Last Active: 5 days ago
Visits: 32.6K
I have the Cast T-Bird Rocker Covers. Changed the Gaskets. Still getting Oil Drips from lower Rear Corner of the Covers. Are there some Gaskets preferred over others? Are "Best" Gaskets better than others? Any suggestions appreciated. Thanks!
FORD DEARBORN
Visits: 113.4K
I've had excellent results with the one and only pair of thick neoprene gaskets purchased from Mummery many years ago. I'm using them on the old style steel covers, if that makes any difference.
Last Active: 13 hours ago
Visits: 38.5K
As usual I didn't completely read the initial post. If the covers have been overtightened you can use a ballpeen hammer and a socket to pop them back out. Also make sure the gasket surfaces are flat and clean. Some of the older covers are very bent from use.
Robs36Ford
Visits: 335.2K
Sadly no is making he neoprene gaskets. They really worked best. Cast valve covers are rigid and if not true/flat to the head surface then it may seep. It is also possible the head is not true also as machining there is minimal. I use Permatex Grey on both sides of the cork composite gaskets from anyone and never have a leak! It is non hardening and thick so you can remove the covers for services and re-apply after washing.
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes. 1968 Merc Cyclone FB GT 390, Getting a better front clip! 1977 Ford F-250 Supercab RWD Explorer Long box. 1976 Chev Camaro RS LT Future rebuild : 1949 Ford F-1
Posts: 1.9K,
Visits: 194.9K
Deleted
Posts: 1.9K,
Visits: 194.9K
I glue the gaskets to all the cast aluminum covers I’ve used. Then use a little grease on the head side. Stops them from slipping, and seals but let’s them release to set the valve. I think Ted has something on that, hope he’ll chime in.
Daniel Jessup
Posts: 2.0K,
Visits: 131.0K
FWIW, this is the way I do my Thunderbird aluminum valve covers and over the past two years I have been very satisfied. I use pretty much the same method as Miker. The link to the pictures and the article is here: https://www.hotrodreverend.com/post/1955-ford-part-111-valve-cover-restoration
Posts: 7.5K,
Visits: 205.8K
The Best Gasket full set of gaskets includes two different pair of cork gaskets for the Y. The thin set with the tabs is for the 1960 and newer tin covers while the thicker set without tabs are for the both 1954 thru 1959 steel covers and the aluminum Thunderbird finned covers. I have no leakage issues when using the thick gaskets on the aluminum covers. I will glue the gaskets to the covers using small dabs of ‘black’ 3M trim cement and then a thin film of white grease on the surface that contacts the head rail so the gaskets don’t stick to the head.
Deyomatic
Visits: 2.4K
Anyone use Gasgacinch? I wish this question was posed a week ago, because that's when I ordered Gasgacinch.
Visits: 32.6K
Thanks Ted. I didn't know the early Gaskets are thicker than the later Ones. I pulled the Covers and blew out the drain holes. See if that helps. Oil shouldn't get high enough on top of Heads to cause leakage. I did find some small Pieces of old Cover Grommet around the Drain back Holes so maybe some got down inside the Head. Take it for a long Drive and see if it still drips.
