Y block porn
Posted By famdoc3 3 Years Ago
famdoc3
Posted 3 Years Ago
Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)
Posts: 178, Visits: 21.8K
Finally got it running! Many good parts and custom machine work. Feast your eyes on this for my Model A Coupe.
http://forums.y-blocksforever.com/uploads/images/f58e19ac-be1c-4a05-82c1-0af.jpeg
http://forums.y-blocksforever.com/uploads/images/b363dfc1-a03b-4b99-9f5f-28f.jpeg
famdoc3
Posted 3 Years Ago
Maybe you can stand on your head to enjoy! Maybe Ted can fix. Sorry Mike
< I flipped the pictures 180° for you.  Ted >
62bigwindow
Posted 3 Years Ago
Posts: 884, Visits: 14.3K
Nice!
Durham Missouri
famdoc3
Posted 2 Years Ago
Slow progress being made, ran it up my street yesterday needs tuning and shake down, but I’m loving the look!
http://forums.y-blocksforever.com/uploads/images/0bdf55b2-5e69-44fd-b0b4-8a18.jpg
Posted 2 Years Ago
Last Active: 5 hours ago
Posts: 4.6K, Visits: 39.3K
Ted Eaton built this one for me a few years ago.
http://forums.y-blocksforever.com/uploads/images/c35dcc18-c8be-41ca-80c3-935b.jpg
Marc
Posted 2 Years Ago
Last Active: 2 Weeks Ago
Posts: 185, Visits: 5.5K
They both look great!
famdoc3
Posted 2 Years Ago
So after one week of trying without success I have decided I must give up (for now) on my Grant Flame thrower distributor. I have a miss and backfire situation that seems to be related to it and I have not found other explanation for it. I have ordered a new distributor as all of the ones I have are pretty well toasted. Replacement of the distributor in my hot rod is hard as it is so close to the firewall that removal requires significant disassembly of the car. What idiot designed this?(me). I have considered some more period pieces but give how limited parts supplies are I will opt fo new. Please wish me luck! There is to much good stuff in this engine for it to not purr like a kitten and roar like a lion on command!
Posted 2 Years Ago
Do not rule out ‘induction’ firing due to spark plug wires running parallel with each other.  Cylinders 1 & 2 and cylinders 6 & 8 are problematic in this regard for the Ford Y.  I did run across an instance with a Grant Flamethrower distributor that had a cracked rotor which was causing some misfire issues so that’s still a possibility. A cracked cap or carbon tracking on either side of the distributor is something else to watch for.  Ignition point gap setting is also critical on the Grant distributors as each set of points is specific to each bank.  You can check that the ignition timing when checked with a timing light is the same for both cylinders 1 & 6 which will verify that the points are set the same.
famdoc3
Posted 2 Years Ago
Thanks Ted for your advice. I happen to be partnered with a friend and have a distributor machine so the points were set and timed on it. Ignition timing was initially quite advanced but has been set to 12 before top dead center. The engine starts and idles well. Before I give up on the Flamethrower I will try separating the wires, hopefully it will work. I’ll check back after the trial. Mike
Posted 2 Years Ago
Posts: 1.9K, Visits: 195.0K
More than once I’ve found a spark problem by backing the car out in the dark and having a look. No lights around, it’s amazing how bright a spark is when it jumps someplace other than the spark plug. Cheap and easy. Couple good raps even pixxxxx’s the neighbors off.
