Visits: 21.8K
Thought I would update. It took a couple of days to change out the Grant Flamethrower for the new distributor. I bought the whole kit- 60,000 volt coil, wires and distributor from CRP installed it today. Snap, crackle and pop are gone! Smoothly takes throttle and winds up tight. Then the rain started so only got to drive it in and out of the shop, but it now runs like a charm. Will be taking the flamethrower apart soon to see what I can learn but for now will take the win. MIKE
Last Active: 7 hours ago
Visits: 39.3K
Careful there are some snap rings in the bottom of the Flamethrower that are a little hard to get to but are set in an aluminum groove. The break easily (a friend told me  ) I often find the rotors are damaged or have voltage tracks on them. They have to be clean and good to work properly. Sounds like you were having a crossfire problem. I had Ted Eaton try one on my blower motor and he said it dropped about 20hp compared to the MSD. They do look neat and somewhat magneto like but I don't know if they are worth it in the long run. I saw online once that someone put 2 VW Pertronics kits in and had some success but that is beyond me. Anyway good luck.
Visits: 21.8K
So I was notified today that my car was accepted for display in the Y block tent at All Fords Carlisle. What an honor. Here’s the picture I submitted. Hope to see some of you there!
Visits: 113.5K
Way to go, nice one, thanks for sharing..........
Visits: 21.8K
So I thought it was time for an update, it’s now running great! My carb guy had put 66’s in the carb initially, I moved up to 70’s on the primaries and it got somewhat better so if bigger made it a little better more might help even better so in went 72’s then 74’s and that’s where I’m at. Runs smoothly, pulls like a freight train and is runs cool. These old motors sure like a little extra fuel and initial timing is at 16 degrees. Overall really happy now. MIKE
Visits: 16.7K
Here is some more... Anybody know this car? Be nice if they showed for Shoot Out
Visits: 21.8K
I don’t know how many will make it to Fords Carlisle but if you go please stop by and say “Hello”.
Visits: 39.3K
I'm planning on making the trip and will be parked in the show field. See you there. Don't miss Tom Drummond in the sales area. Chuck
