Visits: 2.9K
hi all this is an old topic i am sure ,, but what do we think of block and head steam holes. i have an engine that is already done and was wondering do i plug them up or just go with it and leave them alone??
Visits: 497.8K
What do you mean by "Steam Holes" ? How about a pic if what you are mentioning ?
Visits: 3.8K
Morning folks https://www.eatonbalancing.com/?s=steamCourtesy of Mr Eaton. I'm sure he will elaborate. stuey
Last Active: 5 Months Ago
Visits: 22.2K
just leave them.not many drill them anymore.
Posts: 7.5K,
Visits: 205.8K
Visits: 2.9K
sorry no pic, ,but i will try to explain. 2 small holes on the block deck and also the same 2 holes which match up on the heads, ,between the middle cylinders. i believe this was a FELPRO and also others idea in the past. i am inclined to plug them but thought i might seek some advice.
Visits: 154.2K
What gasket are you using? Haven’t read thru all the links, but likely only severe/HP engine would get plugged (?)
6 VOLTS/POS. GRD. NW INDIANA
Visits: 2.9K
i will be using standard monotorque gaskets when i get around to reassemble it. i may plug the drilled holes.
