Visits: 22.6K
? Oil pump is mounted outside the pan on the Y. Are you referring to the pick-up tube? Those can be bent a little to make sure you have ~3/16"-1/4" clearance. If you use thick oil(20W-50), then more clearance is a good idea. Joe-JDC
Visits: 81.0K
The oil pumped mounted to the block is really close to the oil pan flange at the left corner. I’m guessing 1/16. Perhaps I can move the pan to the right. No problem with the pick up tube.
Visits: 81.0K
The oil pumped mounted to the block is really close to the oil pan flange at the left corner. I’m guessing 1/16. Perhaps I can move the pan to the right there maybe a little wiggle room in the the bolts.
Visits: 190.0K
PROBLEY NOT LINED UP,TRYING TO GET THE GASKET IN PLACE. BUT IF NOT OIL FLOW AND LEAKAGE THE RESULTS
Visits: 190.0K
CAST IRON BODEY,VERSUS ALUM ON GEROTER
Visits: 1.8K
I don't recall Ted having said anything negative about the aluminum gearotor oil pumps, and he prefers gearotors. Within the last two years, he did acquire a new batch of aftermarket cast-iron gearotor pumps, but they were/are $200+.
Melling still makes rebuild kits for the gearotor pumps.
