Valve lash is not holding steady
Posted By Brent 2 Years Ago
Brent
Posted 2 Years Ago
Last Active: 10 Months Ago
Posts: 142, Visits: 1.5K
Valve lash is not holding steady after first few runs:
First run: lash opened .006 Second run: the same thing. Third run: I adjusted lash again at .020 cold and then ran the engine for 5 seconds. The lash has opened up again, this time after just a few seconds. I think that if there is something failing at this fast of a pace it would be gone/done already.
The threaded adjusters measure .4360 on the OD of the threads, the ECG rocker ID measures .4395 on the groove. That is a .0035 difference without the depth of the grooves added.
I found two postings that both mention either damaging the threads or using oversized adjusters. Any words of wisdom will be greatly appreciated.
Rocker adj nuts
Loose rocker adjusting screws. - 332-428 Ford FE Engine Forum
Harland Sharp makes these screws but I'm not sure they will fit, threads are +.004 wider and the ball is +.0125
wider, If the 1.200 is the length of just the threads seems like they should be a tighter fit: 7/16 - 20 x 1.200, 3/8 Ball, Ford FE
http://forums.y-blocksforever.com/uploads/images/6271b929-36a9-4e4b-bd6a-ac6b.jpg
famdoc3
Posted 2 Years Ago
Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)Supercharged (456 reputation)
Posts: 178, Visits: 21.8K
Look at the ball and the wear pattern. I suspect you have a pushrod to adjuster ball mismatch. I have made the same mistake before and thought it was that the balls were “soft”. Measure the two and I suspect you will have your answer.
Brent
Posted 2 Years Ago
The wear mark on the ball is pretty small on the tip and it's football shaped.
http://forums.y-blocksforever.com/uploads/images/7cca0aaf-f28e-4008-9dee-e392.jpg
http://forums.y-blocksforever.com/uploads/images/769eb02e-1de9-4438-859c-9ea6.jpg
The Harland Sharp adjuster has a ball +.0125 wider which would produce a tighter fit in the cup.
Posted 2 Years Ago
I would give Smith Brothers or Manton a call. I’ve worked with both over the years with push rods and both offered adjusters. They do offer adjusters that are cups and not balls but your really looking at the threads in the arm.
Have you screwed in a 7/16” fine thread bolt as a test to see if they are as loose as your adjuster now. Just a thought.
Posted 2 Years Ago
I'm assuming good oil flow at the rockers.  I’ll suggest ‘bluing’ some of the pushrod cups and run the engine for about a minute and then checking the wear pattern at the pushrods.  With a locking nut adjuster, I do not think the problem is in the threads but is instead at the adjuster ball to pushrod cup fitment.
2721955meteor
Posted 2 Years Ago
Posts: 927, Visits: 190.0K
HAVE YOU REMOVED THE SPILL TUBES,AND BLOCKED THE HOLE IN THE STAND.IF YOU ARNT GETTING GOOD OILFLOW AT EVERYROCKER,NEXT YOU MAY BELOOKING FOR A NEW CAM ETC
Daniel Jessup
Posted 2 Years Ago
Posts: 2.0K, Visits: 131.0K
From the pictures you have posted, your ball end of the adjuster is not riding true in the cup of the push rod. Once you have some wear between those two parts because the ball is trying to seat, that is what is giving you the extra lash.
Daniel Jessup
Lancaster, California
Brent
Posted 2 Years Ago
The supplier told me that the problem is that the cup is not machined perfectly and the roughness in the cup is grinding the ball.
I have Smith Bros. rods on the way and Harland Sharp had some fat adjusters (.438) with 3/8” ball. Both made in the USA!
famdoc3, you nailed it. , DryLakesRacer I could not find a fatter bolt to try, they are all skinnier, real good idea. The mfg leads helped. Ted, as always, many thanks! 2721955meteor, when I had the covers off and primed the system there was oil at all of the rockers, after the short runs upon inspection everything appears wet. Daniel Jessup, the wear was opening the lash so quickly it seemed dangerous to keep running it. As a result of this group, I have again made another step in the right direction.
I hope you all have a great day!
Posted 2 Years Ago
I’m assuming the Smith Brothers push rods have cups that accept a 3/8” ball and the ball will sit in the bottom of the cup with clearance on the sides. I don’t know about your assembly habits but I recently had both my heads off for a valve seal change along with other repairs and lubed the top and bottom of the push rods with assembly lube. My racing GMC 6’s are made the same and it’s a precaution I take when servicing the engine. I hope it all works out and your problem is solved.
Brent
Posted 2 Years Ago
The new adjusters arrived: 3/8” ball x 7/16-20 “oversized” (these fit the rocker arms much better.) The ball fits the cup in the new pushrods perfectly. The ball on the new adjusters is round; the failed adjuster balls are ground down and are not round.
I am planning to work through the install one cylinder at a time, replacing the intake when the exhaust valve is just opening and the exhaust when the intake is almost closed. I think the rocker arms will move to the side to allow the pushrods to clear except at the four ends the rockers wont slide to the side, It seems to me that I should remove the cotter pin from the end of the shaft to allow the rockers on the ends to be moved for new pushrod install, or, is there a better way?
http://forums.y-blocksforever.com/uploads/images/4b046987-ae20-48d2-924c-8927.png
http://forums.y-blocksforever.com/uploads/images/b62059f0-565c-44ae-84a6-68fb.jpg
