There’s no need to remove the cotter pins from the shafts to install the adjusters in the end rocker arms assuming there is enough wiggle room to replace the pushrods. There’s always the possibility that the rocker arm shaft assemblies will need to be loosened up to change out the pushrods. Let us know on that one. Aluminum heads are easier than cast iron heads in that regard. On my end, it is simpler and quicker to just change out both rocker arm adjusters on a given cylinder by having the engine at the top of the compression stroke on that cylinder. At TDC on the damper, either the #1 or #6 cylinder will be on its compression stroke and once you determine which of those two cylinders is at compression, that’s a good starting point. In your case, the cylinder with lash on both the valves would be the one at its compression stroke. I start at the #6 cylinder regularly on most engines setting the valves just to eliminate an additional rotation of the crankshaft to get to #1 in those cases where #6 is at the compression stroke and not the #1 cylinder. Rotating the engine in 90° increments and following the firing order will save time versus doing it the EOIC method and much easier to keep up with where you are.
Last Active: 4 Months Ago
Visits: 1.5K
If you loosen the rocker hold down bolts and nuts, there may be enough wiggle room. And if that doesn't work, you can remove the shaft assembly to install the pushrods and tighten it down with the pushrods in place. Since there will be tension on the shaft, you want to be sure to tighten them evenly but it should not be a problem. I've done that numerous times.
Visits: 1.5K
Removing the cotter pins should work, too. Do it however you are the most comfortable. I find it easier to remove the assembly rather than replace the cotter pins with the shaft on the engine.
Visits: 1.5K
I installed the new pushrods and adjusters; pulling the cotter pins at the exhaust rocker arms #1-4-5 & 8 is a cinch, every other rocker arm moves freely to the side. The engine sounds so much better, what a relief. The old pushrod cups are rough on the inside and the adjuster balls grind inside of them. I am very thankful for everyone's help. Now it's time to test the brakes!
