replacing front oil seal with engine in car
Posted By Rono 4 Years Ago
Rono
Posted 4 Years Ago
Posts: 1.3K, Visits: 80.0K
Daniel;
That would be very helpful if I knew which bolts went into the coolant jacket and which did not. I the two long top bolts that go through the water pump and timing cover may not be blind holes, so I planned on putting some sealant on them. I am looking at all bolts closely as they come out to to see if they were sealed or not. BTW, I did have a crank damper come apart during the Dyno of my 56 Customline motor and sent it down to the Damper Doctor. They were great and fast. I hope they still are if I need to send this crank damper down to them which I probably will do regardless.
Ted; maybe we can use this picture of my Customline as my signature line.http://forums.y-blocksforever.com/uploads/images/6fedfc1a-55ae-4565-b18c-a64.jpeg
Posted 4 Years Ago
Last Active: 4 hours ago
Signature picture swapped out.  I have a soft spot for those Customline Victorias as I had one of those when I graduated from High School.
DANIEL TINDER
Posted 4 Years Ago
Posts: 1.8K, Visits: 154.6K
Rono (12/29/2022)
Daniel;
I have an old EarlyBird article about plugging all those holes with sealed/cut-off/scribed bolt ends, so parts can be removed in future without fluid spills.  I never did it since I just knew some future owner would install the longer OEM bolts and run into trouble.  Unfortunately, the author wasn’t overly specific re: all the specific locations.
BTW: I just installed the latest gen. water pump & Chris’s modified T-Bird spacer.  I used so much #2 sealer on the gaskets, enough squeezed out to seal the bolt heads. It was an interesting experience polishing off the timing cover casting flash first with the engine/cover in the car.  Couldn’t t have managed it if the radiator wasn’t removed. I actually had to look through the grill to continually check my progress.
6 VOLTS/POS. GRD. NW INDIANA
Rono
Posted 3 Years Ago
So now the damper has been removed and all the bolts are out of the timing cover. One question is are there any tricks in getting the cover off the block? I've been using a block of wood and a heavy hammer to try and get it to move with no luck. Also, discovered this little "hole" on the block mating surface to the timing cover on the driver's side by the upper cover bolt hole that has started leaking a little coolant now. WHAT? A new gasket should seal it but never noticed it before.Casting flaw? This is a ECZ 312 block.http://forums.y-blocksforever.com/uploads/images/096a5c49-e018-4b09-90e8-a73.jpeg
Rono
Posted 3 Years Ago
Ted;
I do not have a T Bird manual and really don't understand the process of centering the crankshaft snout using the PVC pipe. I measured the I.D. of the new seal to be about 1.800".  (The crank damper is boxed up ready to be mailed to Damper Doctor for rebuild so I couldn't measure it.) So do I use a piece of PVC pipe with close to that for the O.D. and then measure somehow the distance between the crankshaft snout and the inside of the PVC pipe? Never tried to center the timing cover before.
Thanks,
Posted 3 Years Ago
http://forums.y-blocksforever.com/uploads/images/a089d5d4-715f-431f-98ed-f393.jpg
That hole you found is there by design and you’ll find one on each side of the block.  It is there in case the gasket that surrounds the coolant passage going to the block from the timing cover starts to leak.  There is a channel around each of those two coolant holes at the block face and those channels (grooves) divert any coolant seepage past the gasket to the exposed weep holes.
The two timing cover bolt holes at the lower side of those same coolant holes are also open holes and not blind.  Those two bolts do require some form of sealer on the threads to prevent any coolant leakage past the threads and to the front of the cover.
As mentioned before, you can get by without a centering tool when reinstalling the timing cover.  Just ensure that the oil pan gasket flange at the bottom of the cover is aligned with the oil pan flange on the block when reinstalling the cover.  The cover is heavy and will have a tendency to drop to the lower position so just watch for that.
Rono
Posted 3 Years Ago
Thanks ted! I really appreciate the info!
Daniel Jessup
Posted 3 Years Ago
Last Active: 2 Weeks Ago
Posts: 2.0K, Visits: 131.2K
If it helps, I used stout angle iron to extend the line of the oil pan rail of the block so that the timing cover would line up.
Daniel Jessup
Red Lion, Pennsylvania
Rono
Posted 3 Years Ago
While waiting for the crank damper to come back from the Damper Doctor, I made this cheap, crude tool for aligning the crank damper in the front seal. A 6" length of 1.250" PVC pipe with a 1/4" x 2" long slot to slide around the Woodruff Key  and then just a plywood disk to center everything in the timing cover. Seemed to work out well.http://forums.y-blocksforever.com/uploads/images/52e335c1-2f82-45ff-a07a-665.jpeghttp://forums.y-blocksforever.com/uploads/images/cb3a7a8a-ac2b-48c5-b229-dc8.jpeghttp://forums.y-blocksforever.com/uploads/images/ec694b2b-598e-4315-a927-2e3.jpeg
