Looking for new head bolts...Which ones are the ones to get?
Posted By Deyomatic 3 Years Ago
2721955meteor
Posted 3 Years Ago
Posts: 927, Visits: 190.0K
I went to the cat dealer,ther grade 8 bolts worked well, some needed trimming. heads of the cat is thicker,  they are true grade 8,which s  a must. my current 292 is 4years old no leaks
 no need to re torq. I did run a botming tap into all threads ,and used a dab of great on the bolts. .torqed to the ford suggested
Lord Gaga
Posted 3 Years Ago
Posts: 464, Visits: 183.3K
Deyomatic (10/5/2022)
Thread deleted...found the bolts and washers from a couple different suppliers.
Man...I hope replacing the head gasket is easier than finding the parts to do it!
Thanks.
I'd make sure the heads were flat before re-installing them.
"FREE SAMPLE"
Deyomatic
Posted 3 Years Ago
Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)Supercharged (855 reputation)
Posts: 294, Visits: 2.4K
Thanks.
Deyomatic
Posted 3 Years Ago
Thanks Ted.
I'll check that out.
D
Posted 3 Years Ago
I typically use ARP for the Y head bolts if grade eight bolts are not provided with the engine.  While ARP does not offer a kit, they are available individually as a custom order.  Mummert also offers the Y head bolts as as kit.  Another option is Fastenal or your local hardware store for grade eight bolts.  Here’s a link to a past thread giving the ARP part numbers suitable for use as Y head bolts.
http://forums.y-blocksforever.com/FindPost162034.aspx
Deyomatic
Posted 3 Years Ago
Doesn't look like ARP makes head bolts or studs for the Y block.  Anyone have a preference for a brand or package that I should look for?
Thanks in advance.
