Posts: 1.4K,
Visits: 2.0K
Dang, Richard, you must have deep pockets (assuming you're talking about the Y-block serpentine kit). If just the smaller wp pulley, less than $100 for 302 pulley. Tbird suppliers have 1-inch smaller pulley for about $100 + shipping.
Last Active: 2 Weeks Ago
Credit card. Dollar down and a dollar if you catch me.
Richard
Last Active: 5 Months Ago
Visits: 81.0K
No I don’t have deep pockets. I think I read $30 for the smaller chrome pulley and shims. No way would I put serpentine system. I run a generator and stock starter.
DANIEL TINDER
Last Active: 42 minutes ago
Posts: 1.8K,
Visits: 154.6K
55blacktie (9/4/2022)
Daniel, did the free shipping include the pump?
No. $30, but everything else free.
6 VOLTS/POS. GRD. NW INDIANA
MplsMike
Last Active: 7 Months Ago
Visits: 92.3K
Deyomatic- do you have a part number for the thermostat you referenced (Napa #6 170 Degree High Flow thermostat)? I found a 160, two 180 and one 195 thermostat on the Napa website, but not a 170. I am driving ‘56 wagon. Do birds use the same thermostats as full size Fords?
MplsMike '56 Parklane Minneapolis, MN
Richard
Visits: 81.0K
Is this the water pump pulley I’m after. 68-69 289-303 short C80E-8A528A 6 1/8 dia 2 3/8 deep
Visits: 498.2K
The NAPA # 6 also goes under the number THM 6 MplsMike (9/5/2022)
MplsMike
Visits: 92.3K
Thanks, Paul.
Richard, I used a Trans Dap 8300 from Summit. 6-1/8 for a Mustang. It was steel chrome and painted it black. It lines up with the closest damper pulley to the engine. Since I have 3 lower pulleys I needed a spacer kit so the fan would clear the third one. I believe I used a spacer behind it also for perfect alignment. It solved my heating up in traffic or idling by speeding up the pump.
Tealy64
Visits: 1.3K
If I need to replace my radiator, I'm also thinking of going with an electric fan. I'm not worrying about originality, I just want the engine to keep cool, look and run good and not lose any HP unnecessarily. Do these fans wire into the current temp sensor, do to they require their own?
1964 Ford F100 w/ 292 Y-block -Central Florida-
