Visits: 2.5K
I'm in the process of installing a PCV system on my 272. Does anyone know of a vendor that has a block off plate for the road draft tube?
They were stock on Thunderbirds. Check with Thunderbird parts suppliers/restorers like Prestige in SoCal.. I found a new one on e-bay last year so I didn’t need to make one. Easier to make in 1/4” aluminum. Can follow the stock opening or be a rectangle.
Visits: 20.6K
I wanted to keep the road draft tube for original look when i put on a pvc so just removed the tube and took a piece of shim stock and put it under the gasket,no leaks and looks original Carl
Last Active: 4 days ago
Posts: 7.5K,
Visits: 205.8K
Visits: 497.8K
Use your old gasket as a template and make one out of 3/16 aluminum or steel
Visits: 2.5K
Thanks everyone for your input.
Visits: 2.5K
Ted, just checked on the Mac's web site and they are currently out of stock. Would a fuel pump block off plate work?
Last Active: 1 hour ago
I think some VW fuel pump block off is supposed to work.
Visits: 20.6K
I could probably come up with a plate if i dug through my old parts Carl
Oh, I'm sure that part is not unique to Mac's so you can probably find it at any vintage Ford parts place.
