Road Draft tube block off plate
http://forums.y-blocksforever.com/Topic160109.aspx
By seishank65 - 3 Years Ago
I'm in the process of installing a PCV system on my 272.  Does anyone know of a vendor that has a block off plate for the road draft tube?
They were stock on Thunderbirds. Check with Thunderbird parts suppliers/restorers like Prestige in SoCal.. I found a new one on e-bay last year so I didn’t need to make one. Easier to make in 1/4” aluminum. Can follow the stock opening or be a rectangle.
By carl - 3 Years Ago
I wanted to keep the road draft tube for original look when i put on a pvc so just removed the tube and took a piece of shim stock and put it under the gasket,no leaks and looks original      Carl
By Ted - 3 Years Ago
MAC’s Auto Parts has those block off plates.  They are called block vent covers.
Here’s the link.
1957 Ford Thunderbird Engine Block Vent Cover, On The Left Side Of The Engine Block (macsautoparts.com)
http://forums.y-blocksforever.com/uploads/images/e647d440-533c-436e-9f45-828b.jpg
By paul2748 - 3 Years Ago
Use your old gasket as a template and make one out of 3/16 aluminum or steel
Thanks everyone for your input.
Ted, just checked on the Mac's web site and they are currently out of stock.  Would a fuel pump block off plate work?
I think some VW fuel pump block off is supposed to work.
I could probably come up with a plate if i dug through my old parts   Carl
Oh, I'm sure that part is not unique to Mac's so you can probably find it at any vintage Ford parts place.
CASCO has the block off plate  # 6869
seishank65 (2/10/2022)
  Give me your address and i will send you a block off plate     Carl
Thanks Carl I was able to locate a block off plate.
