Male/HEI style distributor cap
Posted By TNieland 3 Years Ago
TNieland
Posted 3 Years Ago
Supercharged (98 reputation)Supercharged (98 reputation)Supercharged (98 reputation)Supercharged (98 reputation)Supercharged (98 reputation)Supercharged (98 reputation)Supercharged (98 reputation)Supercharged (98 reputation)Supercharged (98 reputation)
Posts: 34, Visits: 696
Does anyone know if there is a distributor cap that fits the stock y-block distributor with male/HEI connectors that accept 8-9mm snap style spark plug wires?
Any info appreciated.
one piece at a time
Posted 3 Years Ago
Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)
Last Active: 5 Months Ago
Posts: 50, Visits: 21.9K
Standard Ignition AL-482 with slight modification. Make a notch to clear the vacuum advance at the base. Keep it tight or the cap will move around. This is for the International Harvester V8 distributor.
Duane
2721955meteor
Posted 3 Years Ago
Posts: 927, Visits: 190.0K
AL482. STANDERD AUTO  PART. WAS USED ON INTERNATIONAL TRUCKS. NO MODS REQUIRE
another option is the big cap off fords with duraspark,it requires sub cap main  latgcap plus rotor.(should work with petrol conversion
Posted 3 Years Ago
Posts: 1.2K, Visits: 1.8K
Not all y-blocks use the same distributor cap. For instance, the 55 Tbird cap is smaller than the 57 Tbird cap; they are not interchangeable.
2721955meteor
Posted 3 Years Ago
you are probably correct,tho my 55 had latter cap not a tack drive dist,posibly a newer dist tho had vac only advance this site always a place to lean
TNieland
Posted 3 Years Ago
Thanks for the information
I have a 57 distributor with the counter weights will it fit the newer distributor?
2721955meteor
Posted 3 Years Ago
yes
Posted 3 Years Ago
Posts: 3.6K, Visits: 497.7K
How about the rotor - use the one that goes with the cap or a regular Ford 57 rotor?
2721955meteor
Posted 3 Years Ago
ether will work
