Male/HEI style distributor cap
http://forums.y-blocksforever.com/Topic159693.aspx
By TNieland - 3 Years Ago
Does anyone know if there is a distributor cap that fits the stock y-block distributor with male/HEI connectors that accept 8-9mm snap style spark plug wires?
Any info appreciated.
By one piece at a time - 3 Years Ago
Standard Ignition AL-482 with slight modification. Make a notch to clear the vacuum advance at the base. Keep it tight or the cap will move around. This is for the International Harvester V8 distributor.
AL482. STANDERD AUTO  PART. WAS USED ON INTERNATIONAL TRUCKS. NO MODS REQUIRE
another option is the big cap off fords with duraspark,it requires sub cap main  latgcap plus rotor.(should work with petrol conversion
By 55blacktie - 3 Years Ago
Not all y-blocks use the same distributor cap. For instance, the 55 Tbird cap is smaller than the 57 Tbird cap; they are not interchangeable.
you are probably correct,tho my 55 had latter cap not a tack drive dist,posibly a newer dist tho had vac only advance this site always a place to lean
Thanks for the information
I have a 57 distributor with the counter weights will it fit the newer distributor?
yes
By paul2748 - 3 Years Ago
How about the rotor - use the one that goes with the cap or a regular Ford 57 rotor?
ether will work
