ogasman
Visits: 6.8K
I have a 56 block with what I assume is an aftermarket adapter. It has the thin base plate on the block with the slots on the top that is OEM ( I think), then a hard plastic ( rubber?) stepped washer, then the thick outer plate. I assume fiber gasket on the block, then thin plate, then plastic washer, then thick plate ( with the three holes on the top side). This is the way it was when I took it off, don't know if it leaked or not. I have 3 of the chrome acorn nut for the t-bird valve covers, missing 1. Anybody have a good source?
Thanks Paul
Visits: 498.2K
I found some of the chrome acorn nuts at a local hardware store. CASCO also lists the acorn nut, can be bought separately
57RancheroJim
Visits: 112.0K
If I'm reading this correctly you have two plates for the adapter? That doesn't sound right. There should only be one plate.
ogasman (3/22/2021) I have a 56 block with what I assume is an aftermarket adapter. It has the thin base plate on the block with the slots on the top that is OEM ( I think), then a hard plastic ( rubber?) stepped washer, then the thick outer plate. I assume fiber gasket on the block, then thin plate, then plastic washer, then thick plate ( with the three holes on the top side). This is the way it was when I took it off, don't know if it leaked or not.What you have sounds like an early aftermarket spin on oil filter adapter that goes in place of the original cartridge oil filter canister. Those were popular back in the day. In your case, the original ‘thin’ oil flow directional plate used with the cartridge filter was retained instead of being discarded. Those aftermarket units retained the hollow nut in the block that were used originally with the hollow bolt that retained the canister housing to the block. The hollow nut stayed while the hollow bolt was discarded along with the canister. I replace those aftermarket pieces with the later model single piece oil filter nut and the oil filter plate that has a larger hole to accommodate the later model oil filter nut. Only three pieces on the late model (1957 and newer) oil filter plate which would be the gasket, the plate itself, and the attaching nut that also has the threads for the spin on oil filter.
ogasman
Visits: 6.8K
So, should I replace the adapter plate (plates) that I have with a new one? If I need to replace it, who makes the best one?
Thanks Paul
If you get the opportunity to purchase an original I would not hesitate. The stock gaskets in an overhaul set work perfect.
Last Active: 37 minutes ago
Posts: 2.0K,
Visits: 306.7K
OEM - B7A 6882-A
ogasman
Visits: 6.8K
I dug through my stash of y blocks, and found an original spin on adapter. Oh my gosh, was that thing on tight. I had to use the air impact to take it off, and it was hard the whole way off. The threads look good on it, I wonder if lock-tite was used on it. What is the torque on the adapter nut? Should I use anything on the nut ( lock-tite) or just put it on.
Thganks Paul
Sandbird
Visits: 542.7K
The instruction sheet on the picture Kultulz submitted says 25 ft./lbs.
No thread locker, gasket sealer, or extreme tightening is necessary. I do prefer to use the fiber gaskets for the block seal rather than the rubber gaskets provided in some of the filter or gasket kits. Before installing those spin on oil filter adapter plates on the engine, place them on a flat surface and insure that block side center hole in the plate is slightly higher than the outer gasket surface. This will insure that there is enough tension at the outer gasket to keep it from leaking. In those cases where the plate has deformed enough that the outer gasket flange is sitting higher than the center hole, then the potential for leakage has increased exponentially. Here’s a link to an article from the late Walt Nuckels website giving some instructions on how to restore the correct conformity to the plate. http://www.y-blocksforever.com/tech/html/oil_filter.html
