famdoc3
Visits: 21.8K
So I have been accumulating parts for years. A 1959 292 block that is .60 over but not core shifted (Sonics good in all cylinders). A set of nice 113 heads. A forged truck crank that has been magnifluxed, straightened, Cut for g.m. Connecting rods and then nitride. All currently at the machine shop. A YBloke supercharger manifold is here waiting along with Detroit diesel 471 supercharger To run twin v-belts 1 to 1. 1 7/8 inch long tube headers to a Tremec 3650 with an aftermarket replacement for the bell housing to bolt up to a truck bell housing to a jaguar rear. All to be housed in a has is I have already built for my Model A coupe. I think this is my last big build so kind of goin all out. Looking for a 1965 build. We’ll see how it goes. MIKE
Posts: 1.9K,
Visits: 195.0K
That will run like the bat out of hell. Just a question, why the 113 heads instead of the larger chamber 471's. You must have done something more to get the compression down for the blower. I've run both on low boost blower motors, but with a 471 unit you can make a lot of boost with a pulley change.
Have fun.
famdoc3
Visits: 21.8K
Looked for 471 heads for a while and didn’t find and did find super clean 113s. Will take care of compression when I order the pistons wn Hi how will need to be custom as we will be using 6” scruby h- beam rods. Just making it up as we go along. MIKE
Joe-JDC
Visits: 23.2K
Molnar makes a 6.125" Scrub rod with 2.000" journal, and the price is decent. They make several lengths in 2.100" journal, all the way to 6.400". Joe-JDC
famdoc3
Visits: 21.8K
Thanks for the molnar suggestion, they look pretty good. Now a little eye candy (mock-up)!
famdoc3
Visits: 21.8K
Need some advice. Hope to use some after 6” market rods from a scrubby. Have already cut the crankshaft journal to 2 inch. Any suggestions? Will have custom pistons made to make it all work I think. THANKS MIKE
Posts: 1.4K,
Visits: 2.0K
283 SBC pistons have been used, but standard-bore 283 is 3.875; you would need a 0.125 overbore. The block would have to be sonic checked. There's also a limited selection of off-the-shelf 283 pistons (sounds familiar?). There is not much demand for them. You'll have to confirm that the 6" rod is the correct length to use with the 283 pistons.
Often you end up spending more money for machine work, parts that don't fit, etc., while trying to save money using rare combinations. I've not built a stroker, so don't let this be the last word.
Joe-JDC
Visits: 23.2K
Rod big ends will have to be narrowed according to crankshaft journal width plus clearance. Need someone who understands the process or they will mess up the rods and take the material off in the wrong place. Diamond, JE, make custom pistons that will fit your 3.810" bore. If you need more help, I would suggest a call to Ted Eaton for help with machine work, or parts selection, or to order custom pistons. Joe-JDC
Posts: 3.3K,
Visits: 238.8K
As JDC says, you best get some direction from someone liket Ted Eaton or "link" from this site to John Mummert's ford-y-block site, rather than trying to force feed SBC parts into your project.. Mummert has an extensive parts list covering just about everything related to our Ford Y-Blocks.. P.S.- and your very likely going to get bad advice related to the Y-Block from someone in the Bow Tie crowd...
famdoc3
Visits: 21.8K
Well IT RUNS!
