Ford Nationals 2008 Finland
Posted By Hollow Head 18 Years Ago
bird55
Posted 18 Years Ago
Posts: 1.1K, Visits: 58.8K
This chasssis setup is located here in my home town.
There is no phone number on the ad.
Let me know what I can do to help.
Hollow Head
Posted 18 Years Ago
Posts: 1.0K, Visits: 3.8K
Bird55, thanks for your interest! I sent a message to the seller and asked about his adress and number to contact. There was some "get a location" button at the ad, but that map did't tell me anything from here. If he contacts me back and is willing to sell his dragster, could you go and see it for me. Buying and hauling it up here is an another story, but let's not go so far at this point. Have to tell you, I'm on fire about a real Nostalgia dragster w00t.
Hollow Head
Posted 18 Years Ago
Ted, thanks to you also. I didn't know that bolt pattern thing, but would this be ok to use?
http://www.transmissionadapters.com/Ford%20Y%20Block%20to%20Chev%20install.htm
Hmmmm....the price is horrible w00t
or this one?
http://www.wilcap.com/ford.html#312350
Hollow Head
Posted 18 Years Ago
One more to show... w00t
http://www.youtube.com/watch?v=dERFLD7s5mE
Damn, if I just had had that second gear working on that run. Until 660 feet it was pushing real hard, but just when I needed that second gear it never did show up... It just slipped till the end!
Posted 18 Years Ago
Hollow Head (8/17/2008)
or this one?
I’m not familiar with eithter adapter and the pictures of each are not clear or detailed enough to make a decision as to if either is adequate for a performance application.  Flywheel and starter compatibility is what I look for in an adapter.  Previous experience with another Bendtsen’s adapter has the starter attachment being less than adequate and difficult to service once it’s installed in the vehicle but I don’t know the specifics for the Bendtsens GM tranny to Y adapter as that could be improved.
Hollow Head
Posted 18 Years Ago
Ok, Ted. Off topic, what is your best run at quartermile? ET, 60 ft,330 ft, 660 ft, 990 ft and top speed? Our best was that yfreak57's 16,658 seconds, 2,675 7,121 10,516 13,791 and a bit over 80 miles per hour top speed. Feeling was that it pulls quite hard between 60ft to 660 ft but then the shift to second gear destroyes the whole thing...
LordMrFord
Posted 18 Years Ago
Posts: 687, Visits: 9.3K
I think, we can dig a lot more power from engine with wideband lambda and ignition control, but non street legal car is hard to get tuned without a private track.
Hyvinkää, FI
Hollow Head
Posted 18 Years Ago
**it! That FED is sold and I ain't the new owner.  Angry
Posted 18 Years Ago
Hollow Head (8/23/2008)
To date with the Y in the roadster, the best times are:
60’        1.278
330’      3.827
660’      6.021 @ 111.06 mph
1000’    7.953
¼ mile  9.614 @ 135.42 mph
Just keep in mind that war was declared on the Roadster’s weight and as such, the finished weight has been trimmed to bare minimum.  Even the shifter knob is hollowed out.  As an FYI, when I increased the lift on the camshaft from 0.537” to 0.595” with a subtle increase in duration at 0.050” and a ½ point increase in the compression ratio, I picked up almost two tenths in quarter mile et while the eighth mile times all basically stayed the same.  This engine is still normally aspirated with a vacuum secondary carb and no power adders.
Perhaps you’re running out of camshaft?  Or you’re shifting at too low an rpm and falling below the torque band?  I'm shifting at no lower than 6700 rpms to insure that the rpm falls back to the peak torque rpm of the engine.  With a two speed automatic, that becomes critical.
Apache
Posted 18 Years Ago
Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)Supercharged (347 reputation)
Posts: 333, Visits: 1.4K
so we have no idea how much hp and tq the engine is making??? you know the weight of the vehicle?? i could do the math if i had the weight..lol..i'm very curious to this set-up..and how hard was the install..i woudl love to do this on mine...maybe i should just get a 5.0 so i don't mess the y-block up :'( ?
William
1957 Ford Fairlane 500
292 Bored .30 over
Fordomatic
