Almost no compression
Posted By dennis22 6 Years Ago
Joe-JDC
Posted 6 Years Ago
Posts: 792, Visits: 23.2K
A simple adapter with rubber gasket to cover the intake port, and a vacuum port fitting.  Pull vacuum on the closed valve and see if it holds.  Local shop tests all valve jobs by pulling 80" vacuum before letting heads go out door.  Joe-JDC
dennis22
Posted 6 Years Ago
Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)
Posts: 168, Visits: 59.7K
Thanks Joe,
I just checked with the machine shop an they don’t test the heads before they go out.
Would having the compression ring gaps aligned cause a loss in compression (almost none by feel of thumb over plug hole) when hand cranking but be less noticeable when the engine is running?
Thanks, Dennis.
56 F100 - 272 Y Block
NSW, Australia.
blocky
Posted 6 Years Ago
Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)
Posts: 129, Visits: 2.9K
going to make a fool of myself (yet again) but on pic no. 2 is the piston all the way up the bore or is that just the position it was in when you took the pic. also have you got the rings facing up  / down the correct way??
dennis22
Posted 6 Years Ago
Hi Blocky, yeah mate thats just how it was when I took the photo not at TDC.
Checking all the rings are installed correctly is one of my checks once I have all the cylinders out. I’ll measure each bore and piston diameter and compare differences, although the issue is with No5 I still want to check the rest while everything is apart.
Checklist
- check rings installed correctly
- check piston to bore tolerance
- check valves for tightness (carb cleaner or vacuum test somehow)
- any other suggestions?
Thanks, Dennis.
NSW, Australia.
Posted 6 Years Ago
Ring gaps aligned will not result in no compression.  When you consider the exposed area between the gap and crown of the piston compared to the volume of the cylinder, any compression loss will not be detectable by conventional means.  It's something like .00004" square, likely smaller than that.
blocky
Posted 6 Years Ago
just a thought but i hope no 5 is not undersize. good luck.i thought these strange problems only happened to me. cheers
dennis22
Posted 6 Years Ago
Ok, I found an clue to why No5 had almost no compression, turns out My memory had failed me. Last night I pulled No1 & 5 pistons and everything looked ok apart from the odd ring that I snapped and replaced with another new ring when I rebuilt the engine. But the ring I thought I snapped and replaced on No1 cylinder was actually the ring on No5. I just popped out No2 & 6 and they both have serrated bottom compression rings, same as No1 so No5 is the odd one out- see pics below.
Now I don’t have the knowledge or experience to tell me this is the cause of the issue but it sure seems like it could be. When I snapped the ring I called the supplier and ordered 2 more rings (one as extra). When I received the ring I realized it wasn’t the same and phoned the supplier back, they said the original set was about 30yrs old and it was the last pack so they sent me modern replacements. I’m hoping they didn’t send me 2x top rings and now I can’t find the instructions for the new rings. Anyway what do you guys think? Could it be the cause? I’m not sure it’s even the same size as the rest.
No1 serrated bottom face of bottom (same as 2,3,4,6,7,8) compression ring
No1 different angle
No5 non serrated bottom ring
No5 different angle
Thanks, Dennis.
NSW, Australia.
Lord Gaga
Posted 6 Years Ago
Last Active: 8 Months Ago
Posts: 470, Visits: 183.3K
Get a new set of good old GRANT cast iron rings and be done with it!!
(Be sure to check end gaps)
"FREE SAMPLE"
2721955meteor
Posted 6 Years Ago
Posts: 927, Visits: 190.0K
after installing inserts and new valves i would at least lapel valves with fine compound. have rectified several new alum heads that 1 or 2 of the valves where not sealing.in both cases it would be a long time to pound in. best to reface the hardened seat and valve on the cylinder in question,while head is off i would lap the rest . easy to confirm seat corectness with laping by hand
blocky
Posted 6 Years Ago
yes get a new complete set
