PCV in Rear of Valley Tray
Posted By MattsY 6 Years Ago
MattsY
Posted 6 Years Ago
Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)Supercharged (238 reputation)
Posts: 82, Visits: 3.6K
Anyone ever try one of these adapters to use a PCV valve from the rear breather hole in the valley cover? Yes, it's a road draft conversion for a small block scruby, but it looks like it'll fit nicely!
Posted 6 Years Ago
Is that for an in line pcv  ?
MattsY
Posted 6 Years Ago
Yup, for an inline PCV. This seems very similar to an original Ford part that I'm told is rare and hard to come by.
http://forums.y-blocksforever.com/uploads/images/8b36ceab-b52a-425a-923d-781f.jpg
56_Fairlane
Posted 6 Years Ago
Posts: 575, Visits: 14.6K
I found an original one for mine. I would try one of these if I hadn't found one.
~DJ~ AKA "Bleach"
Posted 6 Years Ago
Posts: 1.9K, Visits: 195.0K
I've used these on couple engines. You need to make sure there's a baffle under it, if you've got an aluminum valley pan you have to add one. Otherwise you'll suck a ton of oil.
https://www.jegs.com/i/JEGS/555/52225/10002/-1
30 coupe
Posted 6 Years Ago
Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)
Posts: 130, Visits: 3.4K
I have a couple of the Ford ones, but they would not work with the Edelbrock 3x2 intake I just put on my car. I ended up modifying the valley pan and used a regular small block ford pcv valve and rubber grommet
darrell
Posted 6 Years Ago
Posts: 457, Visits: 22.3K
ive used them before to make a pcv setup.they are not that hard to find if your in an area with lots of old trucks junked.63 and 64 with a 2 bbl carb had them.not sure if they had any earlier.
MattsY
Posted 6 Years Ago
I'm using the original valley pan, so it's baffled. I would just use a PCV valve in the hole with a grommet, but the threaded hold down stud for the breather tube is still there and in the way. It knocks out through the bottom and I don't really want to take the manifold off to remove the tray.
darrell
Posted 6 Years Ago
any i seen juts screwed out from the top
Posted 6 Years Ago
Original was a screw, not a stud.  If it is simply a stud, then it should come out but if the previous owner used loctite to ensure that it doesn't move when tightened or even had a bolt welded to the bottom or something else, then it may not come out very easily.
