Visits: 3.4K
Any one know what John Mummert's aluminum intake manifold clamps sell for? I looked on his web site price sheet, but did not see a price listed. Has anyone actually used any of these? I would like to hear what you think about them. Thanks, ----Jim
Visits: 14.3K
I have them on my engine. They work just like they should and look great.
Durham Missouri
Posts: 7.5K,
Visits: 205.9K
While I was not aware of John Mummert offering the aluminum turtles (clamps) for the Ford Y intake manifolds, they are available from Blue Thunder. For the Blue Thunder Y intakes, the turtles are an extra cost option but I always order them when also ordering the BT intakes. While I use those aluminum turtles with the BT intakes, I’ve never needed them for use with other Y intake manifolds simply due to having a plentiful supply of oem turtles.
Visits: 14.3K
I may have been mistaken on where I got them. I was thinking I got them from John but it's been 5 years since I bought them.
Durham Missouri
The Blue Thunder clamps are cast aluminum with a slight counterbore for a washer. John does show some cast aluminum clamps on his website. http://www.ford-y-block.com/accessories.htm I had to trim some of the clamps for use with my Blue Thuinder manifold in order for them to work better with the manifold. Easy to do with a belt or disc sander. These were produced over 10 years ago so new ones might be different and might not be a problem when used with a stock manifold..
Posts: 7.5K,
Visits: 205.9K
Last Active: 5 hours ago
Posts: 1.8K,
Visits: 306.3K
Visits: 3.4K
Ted, which do you think would work best with an Edelbrock 573 intake? I am a bit "worried" about the off-set on the Blue Thunder Clamps, although I like the looks of them better. Thanks for your opinion, it is valuable to me. I still have not found a price listed any where for either, or a source for the Blue Thunder clamps, other than e-bay
Visits: 3.4K
Thank you to every one who responder to my questions.---Jim
Visits: 32.6K
Ted (1/22/2020)
While I was not aware of John Mummert offering the aluminum turtles (clamps) for the Ford Y intake manifolds, they are available from Blue Thunder. For the Blue Thunder Y intakes, the turtles are an extra cost option but I always order them when also ordering the BT intakes. While I use those aluminum turtles with the BT intakes, I’ve never needed them for use with other Y intake manifolds simply due to having a plentiful supply of oem turtles. I have an Aluminum Offy but no Clamps. Can I use the Ones that are used on the original Cast Iron Intake or do I need to look for others?
