368 Lincoln Build
Posted By martyk98 7 Years Ago
Joe-JDC
Posted 6 Years Ago
Last Active: 3 minutes ago
Posts: 798, Visits: 23.3K
The two aluminum spacers.  Move the two rear ports forward on both sides the same amount to look normal.  You are going to need space for the plug wires and boots on top of whatever cap you use, so use a cap with wires in place and see just how far you would need to slide the Webers/carbs spacer on the long spacer forward to clear, and see if it is possible to blend that amount to the heads.  I have moved ports a lot on spacers and blended them, not ideal, but it could possibly work for you.  You can remove a good deal of the carb spacer bosses, also without ruining their integrity.  Joe-JDC
martyk98
Posted 6 Years Ago
Posts: 160, Visits: 31.8K
Going with Charlie's plan A first. Plate aluminum is at the machine shop.
martyk98
Posted 6 Years Ago
Well, the blocks will do the trick. I need to massage them a little to make it more attractive but at least I can get the distributor on and moving freely.  Still looking for the right distributor, may just have to use an old 292-312 stocker. Can't find a Mallory 387A anywhere.
http://forums.y-blocksforever.com/uploads/images/c461a8a5-793a-419c-bd25-d3b8.jpg
http://forums.y-blocksforever.com/uploads/images/acdce699-77fb-4551-9faf-1af5.jpg
martyk98
Posted 6 Years Ago
Just purchased a 57-63 Ford Distributor with combo mechanical and vacuum advance. Should do the trick.
Cliff
Posted 6 Years Ago
Posts: 908, Visits: 13.9K
http://forums.y-blocksforever.com/uploads/images/59b9d48e-262f-4c99-a3fc-452d.jpghttp://forums.y-blocksforever.com/uploads/images/7c2dc6fe-3a38-45ab-b04f-be86.jpghttp://forums.y-blocksforever.com/uploads/images/8d671c11-7e7c-4293-879a-202c.jpg387 A is a Y Block marine distributor, if that's what you want E Mail me $100.00 plus shipping (this is a dirty used part)
Liqu@aol.com
martyk98
Posted 6 Years Ago
Thanks Cliff, should clean up nice.
Cliff
Posted 6 Years Ago
I have a few morehttp://forums.y-blocksforever.com/uploads/images/10c9e194-355f-4278-ab20-e798.jpghttp://forums.y-blocksforever.com/uploads/images/82973fce-7db5-46b6-927b-fc72.jpg
martyk98
Posted 6 Years Ago
Nice collection!
martyk98
Posted 6 Years Ago
Well, the Mallory distributor isn't going to work. It's just as tall as the 57-62 Ford distributor which doesn't quite clear the intake plenum. I guess we are forced to use the stock 368 dual diaphragm (never knew there was a G in that word). Now I have two vacuum advance lines to run into 8 single throated carbs. Figure that one out!
FYI the height difference is in the base of the distributor where the points are, not the cap. Diameters of all three are almost the same.
Cliff
Posted 6 Years Ago
Mallory has a crab cap that is a lot shorter.
https://www.ebay.com/itm/Mallory-Crab-Distributor-Cap-plus-Rotor-Fits-Fords/143714160675?hash=item2176081023:g:ZnkAAOSwvJFfToKn
