Fe heads
Posted By montana ford man 7 Years Ago
montana ford man
Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)Supercharged (409 reputation)
Posts: 167, Visits: 23.9K
I know this isn’t yblock but I have 2 sets of 352/390 hi-po heads.came off running engines 30 years ago. Like to get them out of my garage. If interested, I will send pictures and numbers.
Last Active: 51 minutes ago
What are the casting numbers? Price?
montana ford man
The cast numbers are ccoae and as I recall these are Canadian heads the other pair are c4ae . Both sets have intake valves a little over 2” so are these just common 352/390 heads? My brothers and I raced several fords in the 70s and I just can’t recall what they are off of. Bad case of CRS. Whatever they are off of, someone can have them for the cost to ship.
Oldmics
Posts: 710, Visits: 78.1K
I have 3- sets of EDC heads from FE engines that Edsel used that need a new home.
Those are the ones with the machined combustion chamber (as I"m sure you already know)
Oldmics (Balto.Md)
2721955meteor
Posts: 927, Visits: 190.0K
the early fes 332cu 1958 with solid lifters had those heads,and no oil galerys to liftrs and could not be converted to hyd lifters.
the lifters wher hollow for most of the length,and wher used with longer  push rods. the rockers where the same as the 406 fe but they used different lifter with shorter  push rods(same  lifer used on the english v6. as well as 427 fe
the heads wher better than later fes as all combustion chambers wher same due to machining and the set i had  the intake valves wher 30dg not 45 . not sure but the canadian fords in 58 used these heads on332cu with 2v carbs,
