Visits: 285.6K
My 1955 Thunderbird has been converted to 12 Volts. I installed a new 1957 12 volt battery tray and HD battery in the car last summer. Batteries to fit this car are hard to find. I bought a new battery from the local auto parts store. The TBird takes a Group 29NF battery. I wasn't able to find a maintenance free 29NF battery. Because I upgraded my brakes to a dual master cylinder, I was not able to use the battery shield. Everything worked fine until this summer. I noticed the battery water level was low, so I filled it. Evidentially, I filled it too much as battery acid came out and into the tray. This made a big mess with white battery powder all over the frame below the tray. I cleaned up the mess and painted the affected areas. I ordered a new tray with the shield still attached. I don't know if the missing heat shield caused my battery to boil over or if overfilling it caused the problem. I will try to make the heat shield work. It may take some fabrication. Anyone ever have this problem?
Posts: 1.8K,
Visits: 306.3K
The 55/57 BIRD has to have the BAT heat shield, the main reason being the high under-hood temperature(s) and the fact of the design of the FYB exhaust manifold and it's proximity to the BAT. Causes of BAT electrolyte spillage and evaporation- 1) Excessive under-hood heat 2) Too close to exhaust (excessive heat) 3) Over charging 4) Over filling 5) Cracked case (from excess heat/over filling) 6) Sulfated BAT BAT TERM corrosion (vented BAT) is caused by electrolyte vapors from heat. Do you have a booster install @ the MC?
Last Active: 2 Weeks Ago
Posts: 1.9K,
Visits: 194.9K
Couple thoughts. Unless the battery was really low, I was taught to check the water after charging. Cold, only cover the plates, not up to the split rim. This was deep cycles on boats, fork lifts, and golf carts. I always assumed (there’s that word) it applies to all batteries.
One way or another, you need to get the heat shield in there. Birds are a problem, and worse with stock manifolds. Even close, just short of touching the battery, it will help.
I solved it by using a small Odyssey battery and hiding it under a cover. I’ve seen some “original” batteries that were just boxes, with a small AGM like the Odyssey hid inside and wired to the exposed terminals.
Visits: 4.0K
My solution was moving the battery to the trunk, It doesn't take that much room, even in the 55 trunk. The best thing I did was to change to an Optima battery, really holds a charge when I don't drive it for a month or two, and no gasses in the trunk.
Don
Last Active: 3 Weeks Ago
Visits: 32.6K
Florida_Phil (8/13/2019)
My 1955 Thunderbird has been converted to 12 Volts. I installed a new 1957 12 volt battery tray and HD battery in the car last summer. Batteries to fit this car are hard to find. I bought a new battery from the local auto parts store. The TBird takes a Group 29NF battery. I wasn't able to find a maintenance free 29NF battery. Because I upgraded my brakes to a dual master cylinder, I was not able to use the battery shield. Everything worked fine until this summer. I noticed the battery water level was low, so I filled it. Evidentially, I filled it too much as battery acid came out and into the tray. This made a big mess with white battery powder all over the frame below the tray. I cleaned up the mess and painted the affected areas. I ordered a new tray with the shield still attached. I don't know if the missing heat shield caused my battery to boil over or if overfilling it caused the problem. I will try to make the heat shield work. It may take some fabrication. Anyone ever have this problem? Interstate sells a regular 29NF Battery. Not sure about MF. If U are using a Battery which U can top up is it MF? Napa sells a Commercial low Maintenance 29NF
Visits: 285.6K
I ordered a new battery tray and shield. I am using hard brake lines to a 1967 Mustang dual master cylinder in my car. I had to make the bends in the lines to the master cylinder tight to clear the battery. The brakes work fine, but there was not enough room for the shield. I will work with the new tray and shield to make it work some how. Everything was OK until I filled the battery. The plates were dry, so I added water to the top of the hole. I am sure I overfilled the battery. From now on I will add just enough water to cover the plates. We'll see what happens.
Last Active: 6 days ago
Visits: 113.4K
Phil, I don't know how the heat shield is formed or secured in place but could it be slotted to allow installing over the tubes? Or? Just my 2 cents - I know you'll figure out a plan, good luck, JEFF.....
Visits: 285.6K
I'm thinking the same thing. The shield is held in place by two angle brackets mounted below the battery tray. I believe I can slot the shield to make room for the brake lines. I may have to relocate one of the brackets. I will post a photo when I have it figured out.
Posts: 1.8K,
Visits: 306.3K
Did you notice the banjo fittings on the install I showed?
Visits: 285.6K
Yes I did. Where did you buy the banjo fittings and stainless lines? Part numbers?
