Battery Leaks
Posted By Florida_Phil 6 Years Ago
Posted 6 Years Ago
Posts: 1.7K, Visits: 306.2K
Oh gee ...
Many sources. AEROQUIP. Try EARL'S PLUMBING.
See what you think - http://www.purechoicemotorsports.com/index.cfm/page/ptype=results/category_id=94/home_id=94/mode=cat/cat94.htm
Posted 6 Years Ago
Posts: 1.2K, Visits: 285.6K
Yes I did.  Where did you buy the banjo fittings and stainless lines?  Part numbers?
Posted 6 Years Ago
Did you notice the banjo fittings on the install I showed?
http://forums.y-blocksforever.com/uploads/images/ad963a72-a66e-4af4-a275-d1fe.jpg
Posted 6 Years Ago
I'm thinking the same thing.  The shield is held in place by two angle brackets mounted below the battery tray.  I believe I can slot the shield to make room for the brake lines.  I may have to relocate one of the brackets.  I will post a photo when I have it figured out.
FORD DEARBORN
Posted 6 Years Ago
Posts: 775, Visits: 113.4K
Phil, I don't know how the heat shield is formed or secured in place but could it be slotted to allow installing over the tubes? Or? Just my 2 cents - I know you'll figure out a plan, good luck, JEFF.....
Posted 6 Years Ago
I ordered a new battery tray and shield. I am using hard brake lines to a 1967 Mustang dual master cylinder in my car.  I had to make the bends in the lines to the master cylinder tight to clear the battery.  The brakes work fine, but there was not enough room for the shield.  I will work with the new tray and shield to make it work some how.
Everything was OK until I filled the battery.  The plates were dry, so I added water to the top of the hole.  I am sure I overfilled the battery.  From now on I will add just enough water to cover the plates. We'll see what happens.
http://forums.y-blocksforever.com/uploads/images/6ae1a613-683c-4968-9627-b8a2.jpg
Posted 6 Years Ago
Florida_Phil (8/13/2019)
My 1955 Thunderbird has been converted to 12 Volts.  I installed a new 1957 12 volt battery tray and HD battery in the car last summer.  Batteries to fit this car are hard to find.  I bought a new battery from the local auto parts store.  The TBird takes a Group 29NF battery.  I wasn't able to find a maintenance free 29NF battery.
Because I upgraded my brakes to a dual master cylinder, I was not able to use the battery shield.  Everything worked fine until this summer.   I noticed the battery water level was low, so I filled it.  Evidentially, I filled it too much as battery acid came out and into the tray.  This made a big mess with white battery powder all over the frame below the tray.   I cleaned up the mess and painted the affected areas.   I ordered a new tray with the shield still attached.
I don't know if the missing heat shield caused my battery to boil over or if overfilling it caused the problem. I will try to make the heat shield work.  It may take some fabrication.  Anyone ever have this problem?
Interstate sells a regular 29NF Battery. Not sure about MF. If U are using a Battery which U can top up is it MF? Napa sells a Commercial low Maintenance 29NF
dbird
Posted 6 Years Ago
Posts: 279, Visits: 4.0K
My solution was moving the battery to the trunk,  It doesn't take that much room, even in the 55 trunk.  The best thing I did was to change to an Optima battery, really holds a charge when I don't drive it for a month or two, and no gasses in the trunk.
Don
Posted 6 Years Ago
Last Active: 6 days ago
Posts: 1.8K, Visits: 194.1K
Couple thoughts. Unless the battery was really low, I was taught to check the water after charging. Cold, only cover the plates, not up to the split rim. This was deep cycles on boats, fork lifts, and golf carts. I always assumed (there’s that word) it applies to all batteries.
One way or another, you need to get the heat shield in there. Birds are a problem, and worse with stock manifolds. Even close, just short of touching the battery, it will help.
I solved it by using a small Odyssey battery and hiding it under a cover. I’ve seen some “original” batteries that were just boxes, with a small AGM like the Odyssey hid inside and wired to the exposed terminals.
Posted 6 Years Ago
The 55/57 BIRD has to have the BAT heat shield, the main reason being the high under-hood temperature(s) and the fact of the design of the FYB exhaust manifold and it's proximity to the BAT.
Causes of BAT electrolyte spillage and evaporation-
1) Excessive under-hood heat
2) Too close to exhaust (excessive heat)
3) Over charging
4) Over filling
5) Cracked case (from excess heat/over filling)
6) Sulfated BAT
BAT TERM corrosion (vented BAT) is caused by electrolyte vapors from heat.
Do you have a booster install @ the MC?
