ignition coil bracket
Posted By 62galxe 7 Years Ago
62galxe
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 145, Visits: 2.1K
Just put a dual feed summit 600 cfm carb on my 292 and the fuel line hits the coil. looking for solutions. My coil mounts sideways. Thanks
Kenny  Onalaska, Texas
Rono
Posts: 1.3K, Visits: 80.0K
Can you post a picture so we can see what options there are?
62galxe
http://forums.y-blocksforever.com/uploads/images/ee6a153a-c298-4e35-b223-0c4d.jpg
Use a bracket like this and mount it parallel to the valve cover.
https://www.summitracing.com/oh/parts/fms-m-12044-a2/overview/
http://forums.y-blocksforever.com/uploads/images/edcf9414-f5a0-4e20-80c0-fc93.jpg
bergmanj
Posts: 257, Visits: 3.9K
45* fuel fittings are also made: Might "clear" the coil as-is.
Regards, JLB
dbird
Posts: 279, Visits: 4.0K
For various reasons I can't use the original coil mount on my 'Bird so it's mounted to the firewall.  Less vibration and possibly cooler,  both good things.
Don
Rono
Is it better to mount the coil in a vertical position if possible?
Only if the coil is oil filled.
Posts: 7.5K, Visits: 205.9K
62galxe (8/2/2019)
Positioning the coil in an upright position is an option.
http://forums.y-blocksforever.com/uploads/images/9b1e9a80-7488-48e0-b341-f446.jpg
Rono
I thought all coils were oil filled although different coils may use different kinds of oil.
