WATER TEMPERATURE GAGE
Posted By 55charliebird 7 Years Ago
That fitting will be too long to fit in the bypass hose of a Y.
2721955meteor
Posts: 927, Visits: 190.0K
my take was the fitting would go in the hot side of the heater hose,not the bypass
Posts: 2.0K, Visits: 306.6K
Let me try again-
To achieve what the OP wants to do is either drill and tap the intake for another sender,
http://forums.y-blocksforever.com/uploads/images/c8161d70-fa93-4ae4-8168-dc9b.jpg
or, make a modification in the WP By-Pass Hose to accept a sensor adapter (have to fabricate). The first photo I showed was just a random example. FORD used the below style on the 58/59 FE -
http://forums.y-blocksforever.com/uploads/images/a7cf5108-4b3b-41fa-b0ae-5feb.jpg
The OEM gauge sender will stay on the cyl head.
2721955meteor (6/10/2019)
How would that work?
2721955meteor
THE PICTURE  OF INTAKE IS EXCELENT IDEA, I DID MYN BUT THE MANIFOLD IS THIN AT THAT POINT,WOUND UP REMOVING MANIFOLD AND SILVER SOLDERING TO STOP LEAKAGE. manifold came from arizona ,no antifreeze with lots of water erosion.
Fairlane57
Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)
Posts: 9, Visits: 6.8K
Hi all, i have a similar problem with my gauge as the sensor unit is not working ,can you advise what i need to replace it with, its for a 57 fairlane 292. are these senders unique to this engine or will others fit ? .I wont get one off the shelf here im sure..
